Rosemary Ainslie circuit demonstration on Saturday March 12th 2011
Started by hartiberlin, February 20, 2011, 06:14:05 PM
Rosemary Ainslie
Steve, it seems that I'm only selectively notified - per email - when posters comment on this thread.  Is this intended? Or is it some malfunction in your system?  I've been given notice of exactly 1 posting.  And to my surprise I find a whole lot of them.
I'll make enquiries at this end - but would be glad if you could see if there's some kind of glitch in your system.
Kindest regards,
Rosemary
Magluvin
hey Rose and Woopy
Woopy   Great show!  =]
Remember Woopy, it is not bemf here, the diode prevents that. =] Cant happen.
In your first test of the circuit with the switch open, Imagine this....
Battery is 5v.
No voltage across inductor
No voltage across the capacitor
The diode is just a one way street and nobody on it  ;]
When we close the switch, the first reactive component is the capacitor. It sees the potential available and wants to be equal with the voltage that is presented and current flows in the circuit.
The inductor builds a field as current flows.
Think of this, as the circuit goes from no charge on the cap to full charge, The current in a normal circuit will decrease as the cap reaches battery level, even just trickling in the last bit to the cap.
Well here we have that same deal, and the inductor is involved in that deal now and as the cap grows in charge, current slows and it will have less influence on the inductor over time till cap is full.
So what we are seeing is, the inductors magnetic field climb and peak, then the peak begins to collapse as the caps voltage increases, the potential difference available to affect the inductor becomes less and less, so naturally the field declines till the cap is full and the circuit has no more current flowing because the cap is now charged and current stops.  NOPE
When we kicked the inductor into motion, the flywheel starts rolling.
When the cap is reaches battery voltage 5v, the inductor is not done spinning, the field is STILL collapsing, forward current Still flows and forces another 4 to 5 volts into the cap.
When the field collapses to nada, our work is done.
Think, collapse is suppose to cause bemf, then why do we not have that here? Instead we got the Merry go round spinning on the amount of energy it took to charge that cap  to battery voltage in series circuit. But what do we see?  The merry go round is still spinning and forces more current into the cap, thus more voltage til the inductors field collapses to no field at all.
No bemf here. Diode wont allow it and your vid just proved what Im saying is truth. ;]
In the vid, I noticed you tapped the battery then released then connected. That little tap cost a vit of inertial value due to now the cap got a small charge before the full connect.  It was not your intention, just a mistake. Now the cap wont have as much continuous pull through the charge from beginning to end because it wasnt empty.  But you did great. The voltage should mostly always be around just less than 2 times batt.
The comment on your vid says different cap size will do wonders, nope.
The cap is the amount of enegry that drives the circuit.  So a big cap, big long currents, etc.
Your test proves Im correct, your inductor wasnt the same, your cap wasnt the same, but bam just about 2 times the voltage.
Im so haaaPPY   IM SO HAAAppy!
Okee   The second setup with the shorting of the cap. That IS the Tesla Igniter pat. way of getting that inductor really spinning because now it is not a declining current in the circuit due to cap charging, you are going all the way baby, kids are flying off this merry go round, and current is moving forward. Now when you release the short, that flywheel pumps that cap way beyond battery voltage.
Thin is, it isnt free. it is pulling current from the battery to charge the cap, that is how much influence the energy stored in the inductor had.
This is all just to show that when an inductors "field" builds  n n N N and on the other pole s s S S  when the current is slowed down or stopped, the field collapses N N n n  and S S s s  and is still pushing forward current, to what ever it is connected to it and will accept it, as seen in woopys vid. ;]  No reverse emf here.  Diode doesnt allow it.
If the inductor is actually disconnected from the circuit by a switch or a transistor that acts as a switch, the field collapse NNnn and SSss trys to force current forward but cant, no where to go. So the inductors self capacitance gets charged really hard, compressing electrons from its tail end to the forward end, and the field is finally zero. Now this compressed charge is very strong and relaxes its spring in the opposite direction(bemf) and the inductors poles s s S S and n n N N, and thus we have a high voltage potential in the opposite direction, and some flywheel effect in the other direction to go along with it.  ;]
Thanks Woopy   This was my precharge circuit when I was doing the sims a while back.
Field collapse isnt the cause of bemf, the bounce of the FEMF during the collapse and it bouncing off of the internal capacitance, that what causes bemf.  But most people I know think that reverse voltage is produced during collapse and thats not the truth.  ;]
Mags
cHeeseburger
Quote from: Rosemary Ainslie on March 23, 2011, 01:09:44 AM
I'm intrigued with this comment.  WHERE did Harti say that 44W of heat costs 50 Watts of battery drain?  I missed this entirely.  Or are you SPINNING here Cheesebreath?  I recall Harti mentioning that there MAY be a loss here - nothing definitive.  And that there is NO LOSS is born out in the instantaneous wattage analysis as indicated by the math trace.  Really Humbugger, Cheesburger, Cheesebreath, whoever it is that I'm addressing, you spin with great aplomb.  But it would be pleasant change if you could simply stick to the facts.
The scope - unfortunately - can only show each cycle as they actually occur.  Between each cycle is a resonating or oscillating condition that the circuit generates.  There is NO OTHER WAY THAT THESE OR ANY OSCILLOSCOPES CAN SHOW THIS.  Are you entirely missing the point here Humbugger?  If you look at Poynty's CORRECT simulation - you'll see he has the same problem.  We are showing the waveform EXACTLY as it is.  Good heavens.  And you claim some kind of expertise to comment?  Then you'll need to get your head around this as clearly you have no idea what we're referring to.
Which makes these comments equally spurious.
It would only be relevant if it did.  It doesn't.  You really need to learn to read our scope values Cheesebreath.  We can only show what the scope shows.  That's a given.
Golly. ::)
Rosemary
Again, Rosemary, since you are addressing me directly, I will try to answer your questions and address your comments.
Where did I get the 50W and 44W numbers and did Stefan agree with them...
The numbers all came directly from you, Rosemary.  44W is what you said the power in the load was, as estimated by the heat signature.  50W was derived by plain old arithmetic based on your scope's reported mean voltage on the shunt of +243mV (that's just about exactly 1A on a 0.25 Ohm shunt) and the same scope's reported battery voltage mean of +50.3 VDC.  Multiply these and you get about +50W flowing OUT of the battery.
Everyone accepted those two basic bits of scope data as good numbers and Stefan agreed that the -5.43 VV your scope got by supposedly multiplying those two positive numbers was obviously wrong.  He attributed the error to your use of offsets to position the scope traces and then not accounting for the offset during the math.
Regarding your scope traces and everyone's constant request that you show the waveform of the oscillation itself, just a few cycles of it, rather than always showing just the burst envelopes at a slow sweep speed...
I am getting the idea from your statements above that you may be misunderstanding the requests.  The burst envelope is that 100Hz 50% duty cycle stuff you always show on the scopes.  Everyone  probably by now accepts that the circuit will oscillate forever once it is started.  Therefore, the bursts are not of much further interest.  We all see and believe that the circuit oscillates at 1.5MHz when the gate is low and stops oscillating when the gate is high.
What people want to see is the actual waveshape of the 1.5MHz oscillation itself.  Just a few cycles of it expanded out to cover the whole screen.  Now this is easy to capture if you know how to work the triggering, the trigger delay, the zoom, etcetra.  And it will show us all some things we want to see that you have never allowed us to see before, like the its actual shape and the relative time and area above and below zero.  No big deal, but I guess it's too late to do it now that the scopes are gone.
The only thing that makes this at all tricky to capture is that the 1.5MHz oscillations take a while to settle to a regular cyclic pattern after the burst begins, so it's hard to try to capture the very first bunch.  They won't all look the same until the jolt that got them started has faded and the regular repeating identical oscillation cycles steadily continue.
This is where knowing how to use the triggering and zoom features is essential.  Believe me, these scopes can capture and display any part of any waveform you want to look at.  You just have to know how to use all the scope's powerful triggering and horizontal timebase features.
By the way, the only material and significant diffrence between my sim and Poynt's is that he uses a repeating pulse generator like you do to stimulate the start and stop of the oscillations.  I purposely used a single-shot pulse to demonstrate that the oscillations will continue forever once started, something you have speculated on but not tried yet, I guess.  My oscillations turn on and off too when I use a repeating pulse generator, but I thought this had been thoroughly demonstrated already and wanted to add some new findings to the knowledge base.
If I left anything unanswered please feel free to persist in your inquiries.
Kindest Regards,
Bryan
Magluvin
Now, if we understand that, imagine keeping the flywheel going buy Kickin it in intervals to keep it going with the shorting the cap technique.
That was teslas way of keeping the discharge cap full in the igniter pat.
Femf.   Or maybe a correct term  FCCFEMF
Field Collapse Continued Forward Electro Motive Force.
Night
Mags
Rosemary Ainslie
Mags - the fact is that there is considerably more charge in the cap than in the battery.  And this, a small battery - has not lost its potential difference as a result of that charge.  That should be the focus.  I'm not sure that it can be argued that the negative current can't flow through the diode.  But nor am I sure that it's that relevant.  What is pertinent is that there is far more energy in the cap than has been delivered by the supply.  And that's what your config proves.  I don't think one need go much further than this to disprove certain claims outlined in thermodynamic laws.  It's HUGE. Hugely signficant.  JUST THERE.
What intrigues me is that - on our circuit - we have, unquestionably, no discharge of energy from the battery during the 'on' time of the duty cycle.  I can't explain this.  In order for that really strong oscillation to take place at all one would expect that there's some transference of potential difference which would show on that shunt.  The only PD that's evident is when it triggers on the negative setting of the gate. To me that may be explained by your forward EMF.  But I'm still working on this.  It may, also, simply be a 'skewed' result due to the inductance on that shunt - as Poynty claims.  But you see the problem then is this.  If one factors in the full effect of the inductance - then one also would need to add to the Ohmage or the resistance on the shunt.  This only increases the benefit.  And this is because the actual advantage has nothing to do with the resistance.  It's to do with that extraordinary antiphase condition of those voltages.  In point of fact, IF power is based on wattage -  VI DT - then - subject to any evidence of this oscillation - we're left with an oversupply back to the battery.  That's the sum that needs to be evaluated.  Either the fundamental measurements applied to power are WRONG - or we have something that flies in the face of.  There are no other explanations.  Bear in mind that the oscillation is not an erroneous indication resulting from a skewed voltage analysis.  If it were then it would never move through the battery and back to be measured at the drain.  It does move back and it is measurable there.
What is intriguing is that this parasitic oscillation - as its termed - seems to be a preferred condition of current flow.  Let's face it.  On the atomic level we know that everything moves to a state of rest - certainly in a gravitational field.  Here we've got a current that simply cannot come to rest?  So.  What are we looking at?  An electromagnetic interaction on the particle level?  If so - then it seems that there's an equivalence in that electric and magnetic interchange that is self-sustaining.  And it's probably always been there.  Just over-looked or done away with as a nuisance. In point of fact, it seems to want to spin - as you put it.  No evident requirement to get to that rest state.
But again.  I'm not entirely sure that the diode stops a negative flow.  But nor am I sure that its relevant.
Kindest regards,
Rosie
