forest
I don't get it.Why not use DC-AC inverter ? Start from 12V battery, measure DC amperage going into inverter . 300W inverter would be good,right ?
the_big_m_in_ok
Quote from: forest on March 26, 2011, 02:47:20 PM
@forest
Do you mean instead of using the power co. mains wall socket, use an inverter instead?
If so, I have an automobile powered inverter that takes input from a 12VDC battery (150W).  The outlet would be replaced by the inverter, a battery added to the left to power it, and a set of polarity-conscious diodes to the battery terminals from the output of the Gabriel Device.
Was that what you had in mind?
--Lee
forest
I had in my mind the way to get rid of power socket by any good sinewave inverter.  ;D Sorry,if that's not possible, I just saw that a natural experiment.
Good inverters have also current limiting breakers.Output should go to transformer and to load. Load and transformer in parallel. then measure output voltage after transformer. It should be 12 V. Transformer rated 80W at least.
If output is fluctuacting above 12V add varistor and a voltage regulator circuit.
When you got steady 12V 80W you know what next...
e2matrix
Yes if this is anywhere close to COP of 8 it should be easy to loop with an inverter and an efficient charger.  See Groundloops charger around here.  A small inverter can be purchased for under $20.  Just having an inverter and a 12 volt battery would even make it easy to verify what power we have with this.  And it would eliminate the need for the toaster as a small inverter may only have around 100 watts output.  Here's one from Walmart for $17.88 :   (handy to have one of these anyway)
140 continuous watts
280 peak watts
USB port
LED lights
120V AC outlet
Built-in safety features
Fused overload protection
Low battery voltage shutdown
High temperature shutdown
Sales pitch over  :D
At COP of 8 you might even get away with looping by plugging in a standard trickle charger to the inverter while powering a couple lights.
cubalibre
@ the cell
Is it right that just any steel pipe bend will help? Available even in copper ...
www.huelsmann-gmbh.de/produkte/bogen-halbschalen-galerie/
