casman1969
For adjusting, may I suggest a ferrite rod approaching the center of the doughnut? This will affect the primary but since the secondary is encased in the steel it should have negligible effect on it.
sergento
Quote from: captainkt on April 08, 2011, 04:12:13 AM
Hi, I hardly ever post but tried Gabriel coil and followed to the letter, (the factory next door to me spins steel donuts ). I found no OU just a transformer, the toaster is probably 1kw like mine so watts in were 1350 on monitor  bulbs on secondary 350W and second monitor reads 347. I was well disapointed .
Keith
hi
if the toaster connected series with the coil , and the coil works like an transformer, then it's impossible to reach nominal power (1000W+350w) at input, at nominal voltage. This values looks like  the toaster and the bulbs are parallel
ramset
Thanks Grandma
Thaelin
   The nay sayer stated he hardly ever posts, true there its his first post since 12/09.
That was to diss this project. Troll in my book.  No matter what you do here, there will
be total negative posts made and if you look, they usually are less than 10 posts total.
But he is a expert and tried it and it failed. Right.....
thay
captainkt
Hi, Sorry if it came across as very negative, I built the devise in 4hrs start to finish because I had all the bits including a steel donut of the correct size. I am a long way from a troll, my workshop is littered with destroyed equipment, I have built dozens of coils etc over the last few years. I am trying to send pictures but am struggling with file size, donut picture is 1.3 meg and do not know how to send as attachment. I have not given up on Gabriel coil am trying with more windings on primary to get rid of dummy load, I had 440 on first attempt. Secondary no load voltage was 290 but loaded the voltage dropped and current rose as normal in
the primary.
Keith
