Free Solid State/mechanical energy
Started by KSW, April 13, 2005, 06:59:25 PM
zepharim
 Thanks ERFinder,
Alrighty then ... we have all jumped ship abit...lol ... man this is so hard to stay on topic ...
its like being a child again and our parents say no ... but we arent soaking it in, it takes lots of bitter pouting and bullheadedness to finally get it throught our stubborn heads no means "stop - not like this" ... lol
Anyway,
Back to the objective: Dont look for meaning but make these understandings your own:
"Let A B represent the poles of an alternating current motor, of which C is the armature wound with coils D, closed upon themselves, as is now the general practice in motors of this kind.
the Armature [c] spins as a result of the magnetic field influenced by the so called induction effect from the energizing coils
1. Poles A are telsa coils
  * Consist of 2 coils (F wrapped around E) wrapped around an iron core
     E - 1 primary coil wrapped around Iron core [Pole A]
     F - 1 secondary energizing coil wrapped around [E]
2. Poles B are electro magnetic coils
  * Consist of 1 coil wrapped around an iron core
My kids up ... i will be back later on today ... someone want to start to discuss this further ... you know, discuss what is being done in each paragraph and ponder and ask questions together at each paragraph?
Sincerely
z
barbosi
First a little note, as far as I know,in  this circuit are not involved high frequency currents. In later patents, the same transformer will use them.
Thanks for the colored drawing, it makes me follow much easier to follow.
Although I cannot say at this moment what is the voltage stored in capacitor, my intuition tells me that is used to store high potential (duh! nobody uses a capacitor to store zero volts).
Also, the connection between green circuit and blue circuit is the Null point. A professor of mine used to say at the exam: "If the circuit is powered with 10KV, and your calculations show that point has 0 Volts, your biggest satisfaction will be not to prove it with instruments, but rather with your life. If you have guts, stick your finger on that spot!"
What bothers me though is why the green circuit goes back (counter clock wise)? Why didn't follow the direction of blue circuit (clock wise)? I think there is the catch. Anyone?
Sincerely yours, me.
When the Power of Love overcomes the Love of Power, there will be peace.
orosado
Quote from: Erfinder on April 19, 2007, 02:46:01 AM
Hello,
Good idea adding color to the figure!  Unfortunately your image is missing a color!  There are two secondary circuits!  These two are connected in series!  The intersection formed by these two circuits is extremely special!  Why?  Review it.  Discuss it!
Lets look at nature for a minute.  In nature when you walk through the woods or through a meadow you should ask yourself what power makes all this possible! What force, or energy is being expressed?  Nature has a power source where is it?  What is it?  Is it electric or magnetic?  How does nature view the electric and magnetic?
It is obvious that nature prefers to produce salts, minerals, which are dielectric materials!  She does produce metals but you find them embedded inside the dielectrics she produces!  This in itself shows you which force nature regards as the force!  Electrostatics (This is a terrible term.  I hope in time it will change to reflect the reality of the nature of this force)!
The energy of the future has a name... Magneto-Dielectric Energy!  Where magnetism is static, and electricity is characterized as a high potential high frequency field, which moves inward (implosion) and outward (explosion) simultaneously!  This action simulates the VOID, the zero point which mainstream science is desperately searching for. We will discuss this further after all the patents have been demystified.
Hello Erfinder,
This is great! I am finally seeing some group progress.
I noticed that when you added the new color, some traces are missing. I added them, tell me if you think this is correct.
Omar
barbosi
Quote from: Charlie_V on April 18, 2007, 09:24:40 PM
It's incredibly ingenious!  I think it would be better if he [Tesla] placed permanent magnets on the rotor.  From the patent, it looks like he is using eddy currents to make it rotate.
It looks to me this is what Erfinder did. As I said being impaired on motors, I cannot see where/how the torque occurs.
Charlie_V
An AC induction motor uses eddy currents to rotate the axial (rotor).  On the rotor, there will be an aluminum or copper loop that is closed.  When the magnetic field from the driving coil (also called stator windings) is generated, a current flows in the aluminum and produces an opposite magnetic field that pushes/pulls against the driving coils.  This rotates the axial.
When you place magnets on the rotor, they change the name to synchronous motor.  The reason for the name change comes in the difference between the two motor's operation.  In an induction motor, the rotor does not turn at the same rate as the frequency of the current.  It lags behind and has a maximum limited speed.  The more load the more it lags, they call this "slip" because the rotor rotation is "slipping" behind the frequency of the current.
In a synchronous motor, the magnets are interacting with the coils.  And in fact, this interaction causes the rotor to match the frequency of the current, placing the rotation in synchronization with the current (thus the term, synchronous).  These motors are typically far more efficient (which can reach close to 90% sometimes) and they produce more torque at much higher RPMs.  The problem is that it's hard to build large magnets at the utility scale, so these motors are limited to smaller power ratings (like 100kW - which to me is plenty!)
Anyway, this isn't really related to the subject at hand, but thought it would help in the long run when it comes to motors and what not.
Laters,
Charlie
