Trawoeer Power Pyramid Version 12 - Electrical output from a homemade pyramid
Started by hartiberlin, June 28, 2011, 04:05:30 PM
energia9
Quote from: bolt on June 29, 2011, 05:37:40 PM
That's it! Bang on correct! I was trying to make the connection when he cut his wire a bit too short then add another two inches with a connector and he said something like "i cut this one too short and it messed up the  swar (VSWR)"   now that lingo is dead give away for a HAM or CB. This is why he had to match that to his 40m rig. Now you confirmed he is a HAM operator its pretty much game over for him and people shouldn't waste any more time here.
You see if you are really tuning into the ambient you do NOT use Hertzian or transverse wave tuned systems they are ALL longitudinal wave systems and are not tuned to a VSWR.
While pyramid systems DO hold some energy for growing plants etc this is well documented AND repeatable but no one else get like 20 watts out of them UNLESS they are fake and hit with least 500 watts RF.
If you dont build it, of course you will never know the truth, you can only theorize because you have not tried it.  this setup doesnt seem to cost lots of $ ,   people dont be discouraged,  TRY it,  then say whatever the real truth is.
here is the proof this tech works, and TRAWOGER copied it from Les brown then rearranged things -
  http://www.youtube.com/watch?v=P7VN6B2GjVI&feature=related
the polyesterene string is the sheeps wool string.
here is another device which prooves that even 500 watts can be withdrawed from the "air"
http://www.rexresearch.com/markovic/atree.htm
and i believe Egyptians did not build their pyramids for only making graves as they would have needed to start making the grave for the king before he was born...
Obviously something is hidden from peoples sight, and i believe the pyramid could deliver hundreds of gigawatts of power if set up correctly..
bolt
Quote from: energia9 on June 29, 2011, 06:19:44 PM
I did say that the system needs to be tuned into longitudinal waves to work as in the case of  Markovitz device but again several people have tried for over 30 years to replicate this too and no one has got more than a few mW output.  The TRAWOGER just doesn't cut it for me sorry as the principle construction is very wrong. People that know me know im usually very optimistic but there are far far better things to select for possible OU and spend your money on instead. I might change my mind if someone ever manages to get more than 1 watt output but i doubt that will happen. The odds of winning the lotto are MUCH greater.
crazycut06
Correct me if im wrong, how come a dc fan work, connected directly to the coil without using any diodes? i've seen a pyramid before that purifies water, but not this kind, powering a 12V halogen lamp.... ??? maybe he use rechargable batteries inside the tube  :o ??? ??? ???
ElectricGoose
This is hillariously tragic!!  You guys truly don't see it do you!  Wow.
fritz
In comparison to 90% of mindboggling theories and wacky electronics experiments in this forum - his actual build instructions are pretty straight forward - and a replication should be quite idiot proof - as long as you get hold on a competent dowser;-))
But its quite interesting which people immediate replied on this thread.
