Trawoeer Power Pyramid Version 12 - Electrical output from a homemade pyramid
Started by hartiberlin, June 28, 2011, 04:05:30 PM
Freezer
Nice work duff and Kazep.  Have you guys found a spot that you will use the pyramid in?, as in using the dousing rods?
I roughly modeled the pyramid frame last time trawoger was here, not sure if it will help anyone.  It basically tells you the angles for a 1000mm frame.
http://img86.imageshack.us/img86/6636/3dvon3.jpg
http://img148.imageshack.us/img148/9339/sidevdy6.jpg
http://img526.imageshack.us/img526/433/tctq8.jpg
http://img148.imageshack.us/img148/1061/bctq2.jpg
I could model the inner part if I had all the specs, I'll have to go through the video again.  Anyways good luck in your builds.
k4zep
Quote from: Freezer on July 11, 2011, 04:24:58 PM
Thanks for the good wishes and info!  We need all the help we can get.  I haven't gotten out the ol dousing rods yet, but will soon
just for the fun of it.  In my youth was a heck of a dowser.............Wire will be here on the 14th.....so in holding pattern, might look at my pyramid tomorrow.......see how I can make it portable.....
Respectfully,
Ben K4ZEP
duff
Below is an excerpt from  a lengthy post by Laborator on the German forum.
It sure would be nice if someone would actually translate some of this. There appears to be some rather interesting posts but I can only get bits and pieces with the translator...
http://www.overunity.de /index.php?PHPSESSID=0b23f432d1584a875fdbdf378f99b2bf&topic=1169.msg23091#msg23091
Thesis:
The ever-existing corona discharge of our planet are the actual source of energy and thus the driving force behind the pyramid of energy. The corona discharges are distributed around the globe are constantly in motion and form, depending on Platentektonik, metal content and soil moisture and salinity in the earth's true birthplace of corona discharges.
The corona discharges are able, through means of  on-metallic clad pyramid through the center of the mirror, preferably quartz sand or quartz crystal in the longitudinal axis to bring in vibration and piezoelectric crystals to stimulate the release of energy with a certain frequency.
To generate a continuous piezoelectricity, the quartz crystal in a capacitor discharge. So now is always enough space in the condenser is present, a DC motor with multi-segmented commutator continuously connected as a consumer.
Only one such engine, with its pulse modes of consumption are the quartz crystal can unload, and store the energy in the capacitor. The engine itself can not utilize the piezoelectricity is directly dependent on the temporarily stored energy from the capacitor.
Other consumers can be connected only to the maximum capacity of the condenser. The consumer can only consume as much energy as it is generated in the crystal at the same time!
Thesis end
k4zep
[/quote]
I'll try and paraphrase:
The ever-existing corona discharge of our planet is the actual source of energy and thus the driving force behind the pyramid  energy device/system. The corona discharges are distributed around the globe are constantly in motion and form, depending on the tectonic plates, metal content, soil moisture and salinity of the earth's true birthplace of corona discharges.
The corona discharges are able, through means of the  non-metallic/mineral clad pyramid with the reactor at the focal point of the pyramid are able to resonate the piezoelectric crystals within the reactor and stimulate the release of energy with/at a certain frequency.
To generate a continuous DC voltage by the piezoelectric effect,  the quartz crystal or sand is built into a capacitor. The amount of capacitance is enough to power a DC motor with  a multi-segmented commutator which also acts as a pulsar to modulate the quartz and
keep it in a operational mode. This pulse modes is essential for the device to operate.  The constant charging and pulse discharging of the Capacitor keeps a minimum amount of energy in the capacitor and allows more energy to be stored and available for use in that device.  The electric motor itself can not utilize the  high impedance/high voltage produced via the piezoelectric effect and produced by the crystals/sand elements within the reactor, but is  down converted to a lower level of DC available in the Capacitance conversion process (many little capacitors being paralleled and dumped into a larger capacitor) and is directly dependent on the temporarily stored energy from the capacitor.
Other loads can be connected only to the maximum capacity of the condenser/crystal piezoelectric process. The loads can only consume as much energy as it is generated in the crystal and converted to usable DC voltage at any given time. IF the load is greater than the device can produce, it will essentially short out the crystal matrix and cease to operate until the crystal/sand is recharged.
Thats my take on it....
Ben K4ZEP
NickZ
   All:
   If I may, I would like to state a different idea as to of why any pyramid, cone, dome, or sphere have power.  As all are energy generating structures.
   The corona discharges are not the cause of the effects, anymore than a cloud is the cause of lighting.  The cause is due to the Earths Vortex and its attributed energies, the Aether.  which you neither see nor is detectable by any instrument made, so far.
  Since you are able to SEE things like the northern lights and other corona type discharges you have erroneously attributed them as the cause of the energy found on Earth as well as inside the energetic foam structures mentioned above. But,  that is not correct.
  The Earths Vortex is what created the planet, and not the other way around. It keeps the Earth revolving as it is an open vortex, unlike the moon which does not spin (closed vortex).  The master or Sun's Vortex along with the Earths Vortex produces all the different types of energies, such as light, heat, as well as all forms of electromagnetic, and non electromagnet energies that are found here on the planet as well as in space within our solar system.  IT is the cause of all forms of visible energy as well as dark matter.  It is this universal energy also erroneously called "gravity" on our planet, that holds the Earth together as a globe, affects our tides, and makes for the changing of the seasons.  So called "gravity" is not a pull to the center, but a push instead, from the outer towards the innermost part of our planet, and out through both north and south poles.  It is this force, the force of the Earths Vortex that is responsible for the increased activity and further concentration of energy in pyramids.  PYRA-MID  meaning fire in the center.
  In the case of small models like we are working with here, the piezoelectric effect is also not the cause of the additional energy. But rather it is again the pyramids vortex invisibly spiraling inside the structure that is causing the charging, activation and effect generation of the capacitor, to separate the negative from the positive charges, thus adding ions or charge to the quartz or sand crystals placed at the focal point of this energy form structure.  Similar to a thunderhead, which when reaching a saturation point, releases some stored up and condensed energy in the form of lighting, which is then dissipated and absorbed by any negative ground.
  Similar to how a magnifying glass can focus enough energy on one spot hot enough to burn organic matter. In a like manner the pyramid produces, or manufacture its own energy from the surrounding Aether and focuses it, by its own vortexial power,  toward the center and out through the corners and top of the structure.
   I know that many will not agree with this "VORTEX THEORY",  but after spending half my life inside of pyramids,  as well as being surrounded by quartz crystals, this is what I've learned to be the truth.
                         NickZ
