SchubertReijiMaigo
QuoteI have decided to apply a modified GNU license to the application, which should protect the device and the mods that get out there, yes we won't get rich but at the same time I think we need to not worry about money at this point.
Money Comes and goes, but time is something you can never get back and is the most valuable resources any one has.
High amps low volts just like the above mentioned patent will serve you well, I've been slowly saving my piggy bank to have a new shell made out of Permalloy which will be much easier to magnetize than the mild steel, it should also separate those magnetic fields even better.
So mod away and break the chains that bind us.
Mav
Good decision, may be if you want to make money you can sell PDF, with construction plan or inject into the grid and not make millions but maybe up to thousands dollars a month !!! And millionaire lifestyle  8) (since you doesn't pay energy anymore) you can over heat your home, your pool, power many light, PC, television, etc, etc for free, make hundreds of miles with your car for free. In long term, we are winner, because oil will skyrocket, wind and solar are inefficient and expensive, nuclear is dangerous, hydraulic is nearly already exploited so what the next ?   ??? :o
Special thanks to Mav and Tesla for discovering this !!!
Good luck.
When the roles are reversed and the secondary is energized instead, is there an induced voltage in the primary?
Mavendex
Quote from: broli on July 29, 2011, 07:34:48 AM
Depends on how many turns are on the shell, I have had it where I get 0 output when the secondary is energized, if I add 600 more turns I can get a few volts.
Thanks for the answer, also can I ask how or where you'll be getting your new permalloy shell from?
On the other hand 4 special toroids could do the trick, 2 for inner and outher wall and 2 identical ones to cap the top and bottom. Might get pricy consdering the size.
Mavendex
Quote from: broli on July 29, 2011, 02:41:52 PM
From the same guys who made my last shells, L&S they do a real good job, kinda slow but a real good job. You can buy plates of permalloy online in 30" by 14" pieces with varied thickness. It was actually easier to find a single plate of permalloy than a single sheet of CRGO steel, to get the electrical steel I would have to pay something like 40k for a 40,000lbs coil of it, which is something I say no to hehe, Ill just go with the really really good material that I can get by the plate.
