Free Solid State/mechanical energy
Started by KSW, April 13, 2005, 06:59:25 PM
nat1971a
Also regarding closed coils
He describes them as "coils with their respective ends joined, so that each coil forms a separate closed circuit" patent 382279 line 57
also described as "coils closed upon themselves or connected in a closed series". line 19 455067
"closed coils represent an inductive resistance" p455067 line 72.
and finally describes how the coils are configured "the armature coils are wound or connected in such a manner that adjacent coils produce opposite poles" p455067 page 2 line 29
This confirms what I stated earlier about the coils configuration.
N.
Charlie_V
I think Tesla used ancient astrological technology to contract and then expand the quasi-dimensional hyper energetic radiant space surge impedance.  Where by increasing the oscillations in a static-electric pulse, inducing a stationary magnetic flux on the coil and liberating the quantized energy states of the material.  This produces a void in the radiant vortex that correlates with what Erfinder is saying.
I believe the compressing of the QDGERSSI (quasi-dimensional hyper energetic radiant space surge impedance), which we can assume is similar to pressure in a thermo-nuclear reactor core operating at 150 parsecs, also explains the longitudinal ether dilation as seen by both George Lopez and Ronald McDonald.  This "pressure", if you will, is what generates both the aurora borealis, solar winds, and Rossy O'Donnell.
I think Erfinder, Grumpy, brnbrade, and nat1971a are correct when they talk about closed coils and the effects of short wave resonance in the mathematical Vedic manipulations of Jagadguru Swami Sri Bharati Krishna Tirthaji Maharaja.
So you see, this can only point to three things: the octave amplification of pure harmonic unity, space time curvature, and the operation of sun screens past SPF 15.
Maybe not............ :D
Trump
Yahoo Groups,
Has anyone else had any problems with the Yahoo Groups? I keep getting messages to Reactive the E-mail address. When that happens you don't get updated messages.
Information,  there is so much information coming in and everyone is doing the most they can to keep on track and try and get everything they can out of the patent number one. Gee I wonder how long it will take to cover the next patent? Erfinder, I think you said it took you years to find out what you know now? I am sure you have fun with some of the statements we have, I hope you will have the patience to keep us on track and to not let us sink into the deep water and drowned. I know that you want us to learn and learn is what were trying to do. Seems it is like the Tesla coil as the knowledge is like the sparks coming off the coil as each spark is someone's thoughts and knowledge and its shooting out  everywhere, but which spark is the one we should follow?  I read and read and re-read the patent. and I try and stick to just the patent, so I will hopefully keep on track. Erfinder, Is there a better way for us to get the information you are wanting us to get?  Hopefully we are gaining ground, but not sure if we are gaining one day and losing the next day?
Trump
Maximumgravity1
Charlie_V, if you could just speak outside of mainstream jargon, I think we might be able to finally communicate....LOL
AS I see it, this is beginning to appear as strictly a mechanical method to change the phase 90? between the primary and secondary voltages.  I am going to try to talk this through, I hope it makes sense.
If we assume that a transformer adjusts voltage, I think we should assume the capacitor adjusts current.  In looking back to the quote I posted earlier:
Quote"The secondary of the coil possesses usually such a high self-induction that
the current through the wire is inappreciable, and may be so even when the
terminals are joined by a conductor of small resistance. If capacity is
added to the terminals, the self-induction is counteracted, and a stronger
current is made to flow through the secondary, though its terminals are
insulated from each other. To one entirely unacquainted with the
properties of alternating currents nothing will look more puzzling. This
feature was illustrated in the experiment performed at the beginning with
the top plates of wire gauze attached to the terminals and the rubber plate.
When the plates of wire gauze were close together, and a small arc passed
between them, the arc prevented a strong current from passing through the
secondary, because it did away with the capacity on the terminals; when
the rubber plate was inserted between, the capacity of the condenser
formed counteracted the self-induction of the secondary, a stronger current
passed now, the coil performed more work, and the discharge was by far
more powerful.
The first thing, then, in operating the induction coil is to combine capacity
with the secondary to overcome the self-induction."
Capacitance is a circuits ability to store energy.  "Self inductance is defined as the induction of a voltage in a current-carrying wire when the current in the wire itself is changing." (Reference).  Tesla states above he could create a capacitor (condenser) just by inserting a rubber plate between the discharge of two wire screens.  The reason being, it changed the amount of current that could flow between the two screens.  How?  By increased resistance.  This dielectric rubber caused the voltage to flow back down to the energizing coil, because it was sensing a lower potential coming from the source, and the capacitor did its job - it flowed energy back to the coil.  It then induced more voltage into the winding because the capacitance was removed from the terminal (of the secondary).  This removed the self-inductive resistance, which somewhere was stated that it only saw the ohmic resistance of the coil.  This has the net effect of MORE voltage being induced into the coil.  When this happens, the coil itself begins to build up more capacitance, due to self induction again, until it is strong enough to build up enough current to pass through the dielectric (in this case, the rubber plate Tesla was holding between the two screens).  In this manner, by increasing the resistance of the capacitor, you are able to manipulate the CURRENT flowing through the circuit.  In so doing, since the CURRENT is just along for the ride, the voltage has to be increasing - in this case due to higher frequency of bouncing back and forth between the induction of the coil, and the dielectric of the capacitor.
So, back to patent 464,666
"Another well known method or plan of securing a difference of phase between the energizing-currents of motors of this kind is to induce by the currents in one circuit by those in the other circuit or circuits;..." (L34-38)
"...my invention consisting of placing a condenser in the secondary or induced circuit of the motor above described and raising the potential of the secondary currents to such a degree that the capacity which is in part dependent on the potential need be quite small.  The value of this condenser will be determined in a well understood manner with reference to self-induction and other conditions of the circuit, so as to cause the currents which pass through it to differ from the primary currents by a quarter-phase." (L49-61).
OK, maybe slight exaggeration in the highlighting of the term current, but I think it emphasizes the point.  Can the current be raised by mechanical means (stronger capacitor) without affecting the voltage?  I don't believe it can.  The opposite appears to be true however, but irrelevant at this point.
Now, ERFINDER has told us that the 12 energizing coils are acting as the plates of a capacitor, and can be arranged in other ways for different work.  Keeping in mind that Tesla showed how the increase of capacitance can cause a direct increase in discharge, and higher current to flow, it seems to be a simple calculated mechanical advantage step up to create the circuit to function 90? out of phase.  This would be done by using the proper size capacitor, which would cause the two secondary circuits ("F" and "G") which are polarized out of phase from each other by the physical construction of the circuit to remove the capacitance from each other, and allow the energy to continue to build (through the capacitance of the individual energizing coils)until it reaches the appropriate level, then discharge through the capacitor at the proper 90? out of phase.
Of course, "determining in a well understood manner the value of this condenser" seems to be where a bit of the secret lies.  Somehow, I have a feeling that harmonics discussion way back when might have something to do with it.
nat1971a
I am under the impression that Tesla is using a variable condenser in the patent to control the quarter phase but he doesnt specifically mention it in that patent. (works like a radio tuner)But does mention it in patent 568 178 p2 line 115
He also mentions in his lectures:
"One more to improve, the proper difference of phase is obtained b/w the primary & secondary currents by a condenser, self induction, resistance or equivalent windings"
Reference L-69 Nikola Tesla, lectures patents, articles book
