FUELLESS CAR PROTOTYPE by ISMAEL MOTOR
Started by luishan, September 08, 2010, 11:50:07 PM
konehead
hi forest
there are no diodes in the "repelling force" coil blast thing...he told me they will lbow up no matter what since the powr is so extreme (and it is) '
but most probably diodes in the other techs he has (such as in his MEG which powers his electirc car)...there are diodes inside mosfets and IGBT and like things so basically he was telling me the way he collects the backemf requires no didoes...
In the coil-blaster, there is inner primary coils (bifilar 22GA) that takes the hit of the resonate-chopped 7500VDC, and when this inner primary ignites from the jolt of juice, it creates a huge electromagentic field streching say 4 inches or so around the primary with very stong force....so this is normally wasted power, and Ismael wraps lots and lots of secondary winds all around this primary, and behind it too I bet (thats what I do too) and so now all of that field induces lots of power into the secondaries - I call these secondaries pikcup-winds.......
AND this big pickup wind picks up the backemf/recoil too, and then he SHORTS that, 5 times at peaks and jacks up the voltage into cap even more - all this without affecting draw to primary...power goes out to load, or is "recycled" (as I assume the coil blast does) when primary swtihc is off and "source" is disocnnected from caps then they hit load or recycle.
ITs all very complicated including the cascading-DC way he ramps up voltage to the cap from 12V to 7500VDC in 12 seconds between blasts.
To say this is elementary science and anyone can do it is pretty wishful thinking.
He employs coil-shorting too, (as far as I know) in the cascading DC step-up circuit, this is probably inside the recycling-circuit of the recovered power from the seconary/pikcup winds....
I dont know how he eventually collects it all into DC caps without diodes probalby some clever switching dont know for sure but that is "where" it comes from in what I described....same thing really with automotive ignition coil - one coil in it is 12V and then other coil around it is very thin winds so you get the 15KV spark from that and also the backemf/recoil is collected too byt hainve coil around coil.
anyways, no diodes, no iron, HV, coil shorting 5 times at peaks, and EVERYTHING is in resonate or harmonic fregueincies...this is coil-blaster, not his MEG whihc is differnet thing...the MEG powers that electirc car in all the videos not the coil-blast technique...
forest
konehead
Thank you, I understand now. Still the bigest problem for me are diodes and synchronization, but I'm just starting only...
jbignes5
 I myself am struggling to understand this but I think I might have a clue. This effect he is producing is not being generated in the normal fashion of our traditional electronics. So trying to apply traditional theories to the operation will do nothing for proof. He is generally working off the basic premise that Tesla used in all of his high voltage experiments. Capacitance discharge into a coil will always net huge potentials. Especially when the coil is a very low resistance bifilar coil which Tesla patented. So from the Tesla patent we will see that:
"I have found that in every coil there exists a certain relation between its self-induction and capacity that permits a current of given frequency and potential to pass through it with no other opposition than that of ohmic resistance, or, in other words, as though it possessed no self-induction. This is due to the mutual relations existing between the special character of the current and the self-induction and capacity of the coil, the latter quantity being just capable of neutralizing the self-induction for that frequency. It is well-known that the higher the frequency or potential difference of the current the smaller the capacity required to counteract the self-induction; hence, in any coil, however small the capacity, it may be sufficient for the purpose stated if the proper conditions in other respects be secured. In the ordinary coils the difference of potential between adjacent turns or spires is very small, so that while they are in a sense condensers, they possess but very small capacity and the relations between the two quantities, self-induction and capacity, are not such as under any ordinary conditions satisfy the requirements herein contemplated, because the capacity relatively to the self-induction is very small.
In order to attain my object and to properly increase the capacity of any given coil, I wind it in such way as to secure a greater difference of potential between its adjacent turns or convolutions, and since the energy stored in the coilâ€"considering the latter as a condenser, is proportionate to the square of the potential difference between its adjacent convolutions, it is evident that I may in this way secure by a proper disposition of these convolutions a greatly increased capacity for a given increase in potential difference between the turns."
Reference: http://www.teslauniverse.com/nikola-tesla-patents-512,340-coil-for-electro-magnets
So what this man has done is exactly what the bifilar was always intended to do and that was to totally convert the current to super high potential via the increased speed at which the cap dump goes trough the coil due to the lower BEMF. This is cancelling the BEMF totally and allowing the current dump from the cap to shoot trough the coil at incredible speeds. This in turn increases the magnetic response from the environment towords the source of this event without having to initiate a magnetic event in the first place and it bounces back and forth between the final cap and bifilar coil(capacitor) causing a huge generation in the external pickup coils. This is Tesla Tech at it's finest.
Here is also another clue using more traditional technology: http://www.teslauniverse.com/nikola-tesla-patents-390,721-dynamo-electric-machine
Please read and reread these documents over and over before dismissing these claims. Tesla used non traditional armatures (field coils) they were toroids. That meant the magnetic field was wholly contained in the core toroid. Just as Leedskanin proves with the phm. The only other field that could possible be present is the electric field emmanating from the copper wires and Tesla knew everything there was to know about the electric field. Once separated from the magnetic field there is no lenz drag and one could generate huge amounts of energy without the lenz force because it did not effect the source.
Here is a close up of the core he used: http://www.teslauniverse.com/nikola-tesla-patents-382,282-electric-converting-distributing . They must be closed upon them selves meaning forming a circuit. So if you use iron wire it must be circular in nature or closed looped to get the effect.
As usual we have misinterpreted the patents and that is due to Tesla needing to have the basis of his real invention in the public eye. He knew one day someone would decode the puzzle and hopefully it has been decoded properly.
Has anyone tried to detect a magnetic field around a pmh? Trust me there is none because it is locked inside of the core forever circulating. This circulation is what he mentions about the circuit having inertia. When you trap the magnetic field inside the core the only other field that is present is the electric field and that field is solely responsible for the generation of currents in the generator section of the second patent. The second patent can be utilized all on one shaft if the field coils go in the opposite direction of the turning motor. If the exciter is of a high voltage type meaning many many windings of fine mag wire you can see that it is pure potential that turns the field of the field coils. The generator rotor is a heavy copper wire like house wire and when the electric field cuts that huge currents are pulled into the system. Plus the more you put drag (clutch for a vehicle) on the motor the more the currents gets generated if you follow the design in the second patent compensating for the motor to amp up and try to go back to a steady state.
I don't have it all worked out but I think People like Konehead can more then figure this out. Give it a shot and let me know what you think.
Poit
another few more months till i will be proven right.... that is that in 3 or so months would make a year since his first claim of a "break through" etc etc blah blah invention... and i said that in 12 months nothing at all would of happened .... ill renew my "bet" for another 12 months.... frick.. how about 100 years? thats how confident i am that this is BS
forest
