DeepCut
Hi all, so we're all on crack and drugs and drink ?
I'm having a cup of tea and a ciggy, but i'm boring like that ;+}
@Luc and Keyho, Romero's circuit is the same as the standard SSG driving circuit but with a Hall sensor rather than a coil.
@ Thane,
thanks for advising me not to connect them serially !
Results of multi-coil tests :
No coils present.
hz : 502
ma : 452
1 coil present open circuit.
hz : 417
ma : 472
1 coil present short circuit.
hz : 505
ma : 445
2 coils present, both open circuit.
hz : 393
ma : 475
2 coils present, both short circuited.
hz : 514
ma : 438
3 coils present, open circuit.
hz : 388
ma : 474
3 coils present, all SC
hz : 511
ma : 440
I think i understand why two coils outperformed three with my setup.
Because it is a single-magnet rotor, the two coils on opposite sides of the magnet are synchronised in the sense that they both experience the flux change at the same time, whereas the third coil, which is in the middle of the other two, experiences flux-change after the first coil and before the second of the other two coils, so the timing is wrong and possibly fights against the effect from the other two.
I confirmed this by moving the third coil closer to one of the others and performance goes up.
Obviously the single-magnet design has it's limitations, the physical space required for many coils isn't available and the timing problem.
I'll be making a multi-magnet rotor now but in the meantime i'll experiment with getting power out of this device, time to order some high-current wire ;+}
All the best,
DC.
matthewklinko
Quote from: kEhYo77 on November 01, 2011, 11:56:01 AM
Let There Be Light! 660W light out -700W back to the grid (European 230/50) :D
... I just have to try that! Thanks CRANKYpants
Using that circuit simulator, you are graphing power consumed.
The source does not consume power , it generates power hence the negative power.
There is no overunity it that.
If you don't believe me, do your own calcs, graph the voltage ad current and multiply them, and you will get positive power.
DeepCut
Can anyone recommend a good circuit simulator ?
Cheers,
DC.
Magluvin
Hey Deep
Falstad.com has Circuit, as shown in posts above  ^   =]
Its very decent for free.
Poynt uses Spice, he may be able to help you with that.
I havnt used it yet.
Mags
SchubertReijiMaigo
The negative power in sims is not OU: It's a manner to display the power draw from source, if you have for example -10 watts peak, its' meaning you REMOVE 10 watts peak from source and not you inject it !!! It's a beginner error that I've learned few day ago when experimenting. I'm skeptic to extract resonance directly like this without High Q and Transverter diode plug clipping circuit (extracting without killing the resonance...)
