johnny874
  @All,
This might simplify the idea. The pivot on fulcrum B can have weight C.
It's mass can equal A + B.
If weight A has an antennae (for lack of a better term), a tab (pictured, like used on an umbrella) can restrict the downward movement of weight A. It slowly moves outward.
It's potential would be relized by weights C & B. Then on the follow through (after bottom center), as weight B drops, it accelerates weight A, just slightly. This would align all 3 weights for the return swing.
The nice part about weight C is that on the follow through, it's inertia would help move weights A & C. This would require weights A & B pivoting at weight C.
Who knows, fulcrum A might not even be needed. Still, if used could make operation of the device simpler.
        Jim
AB Hammer
Quote from: johnny874 on December 03, 2011, 11:04:22 AM
   Alan,
When weights A and B start their downward swing, weight B would be supporting weight A.
This would give them both the same momentum. When fulcrum A starts lifting weight A, weight A will have a shorter path to follow than weight B does. This would cause weight A to be pushing weight B.
As far as pendulums and swings go, weight B does not need to move at the ends of it's pendulum. I showed this as part of the mechanics children use.
        Jim
edited to add attachment.
edit; it might just be that when fulcrum A starts lifting weight A that weights A and b have the same distance to travel. If so, then the energy developed when weight B is supporting weight A is the extra impetus into the system which would allow it to be a dynamic self perpetuating pendulum. A tribute to their efficiency.
A part of the reason is that weight A would be dropping more than it's own path allows for.
Greetings Jim
I still don't see you getting an advantage but good luck on it.  When dealing with acceleration of swinging. I would suggest watching kids on the playground swing. By dropping themselves and kicking out to accelerate.
With out a dream, there can be no vision.
Alan
johnny874
Quote from: AB Hammer on December 04, 2011, 08:56:27 PM
Greetings Jim
  Hi Alan,
As you know, I am engaged in learning the build process for what I consider to be Bessler's working wheel.
With this, there is one important thing to remember, work equals mass times distance. And it seems that torque is to be considered just the same.
What this means is if someone tries to rotate a wheel using solid weights that they have to consider the distance the weights travel and their average position from center. That's to keep it simple. And using 4 weights as an example, the weights being lifted have to move close enough to the axle to travel less distance than those falling. A very difficult thing to do.
With swinging weights, the efficiency increases. And as one weight drops, it can lift with no friction, a weight dropping can lift another weight the same height. While Bessler said he used 6 and 8 weights, he did not say on which wheel.
With a wheel based on a pendulum type behavior, more than 2 weights can be used. But 2 weights might work best with the mechanics. And the best thing about something like this is people would believe that everything is rotating with the wheel. But as only the hands on a watch rotate, it would be the wheel and not it's mechanics that would be rotating. this would put people on the wrong trail from the word go. Thus they would never figure out Bessler's subterfuge.
        Jim
johnny874
   Alan,
this might help simplify things for you and everyone else.
As has been mentioned, bessler made time pieces. these required great skill.
And as you once asked in Besslerwheel, what could fit inside a wheel that
is 4 inches (10 cm's) wide ? Swinging levers could. And to throw a little math
at you, if a 1 meter long levers are used with a 7.5 cm radius cog, an over balance of
5.88 cm's. Or the CoG would be 94.12 cm's. And if it rotated 1/4 turn, then the Cog
would be 82.345 cm's. That's a signifigant difference.
As for the wheel itself, how much would the frame of a 10 cm wide wheel weigh ?
Not much, especially if it is covered with material as Bessler's were known to have.
Just don't expect it to do much work, but it could rotate if the math proves to be correct.
By the way, remember the spinning top that was a clue ? It could roll, couldn't it ? Like
maybe if a line were attached to something else ? And the line was attached to both ends
to pull it evenly ? just a thought.
        Jim
edited to add picture showing a straight line pull.
Merg
latest from veljkomilkovic.com:
"Energy Globe Award" for Veljko Milkovic's Pendulum Pump
On November 25, in the Austrian city of Wales, the prestigious "Energy Globe" awards for the best global environmental projects were presented and this year's world and national winners were proclaimed. Veljko Milkovic’s innovation “Hand water pump with a pendulum“ was proclaimed national winner of “Energy Globe Award 2011“ for the Republic of Serbia.
On November 25, in the Austrian city of Wales, international foundation ENERGY GLOBE (www.energyglobe-foundation.com) traditionally rewarded projects which improve energy efficiency and renewable energy sources and presented the awards to international and national winners in its prestige Energy Globe Award (www.energyglobe.info). International foundation ENERGY GLOBE, based in Austria has been giving the most prestigious international award for environment preservation in the world since 1999. Among other things, ENERGY GLOBE award is intended for all the projects in the world which rationally, carefully and efficiently treat energy sources including renewable energy sources.
This year’s final ceremony was held in the Austrian energy city of Wales, in a beautiful setting of the trade fair and conference center "Messezentrum NEU” (www.messe-wels.com). Annual award "ENERGY GLOBE" was presented on a gala manifestation under the name “Olympics for our environment” which gathered representatives from over 40 countries, more than 1000 guests, top-ranking laudatory speakers and a huge crowd of press and television representatives. http://www.energyglobe.com/news/details/category/2/id/1823/
Almost 1,000 projects from 105 countries was participating for this year's award "Energy Globe" and from those who met the criteria of the international jury, the best project from each country was awarded the national "Energy Globe" award http://www.energyglobe.com/en/award/latest-winners/national-awards-wels-2011/ from which the top 15, divided into 5 categories (earth, fire, water, air, youth), were also nominated for global award "Energy Globe World Award 2011". http://www.energyglobe.com/en/award/latest-winners/nominees-world-award-2011/
International jury proclaimed “Hand water pump with a pendulum”, an invention by Serbian academician, researcher and inventor Veljko Milkovic (www.veljkomilkovic.com), the national winner in the Republic of Serbia for 2011 for his energy-saving technology for water supply and irrigation. http://www.pendulum-lever.com/pendulum-pump.html
