Pressure Trik
Started by lupenterzo, December 07, 2011, 01:56:06 PM
lupenterzo
Good evening. I think this should be a method to convert the force of gravity into energy. As you can se there is a pool on the left with inside an empty cilinder linked to a container on the right. Ther's an hole in the container on the right to attach a flexible tube.
I think that i put a weight on the container the pressure rises on the cilinder in the pool,having same dimensions of the container on the right.
But if we have an hole in the container,pressure wil let rise the cilinder and the container.
My doubt is if the flexible tube pull down the container equalising forces.
Thank you
lupenterzo
I think differental surfaces (one with hole,one not)corrsisponding differental forces. If could work,the weight will remain at the starting point generating energy... comments? Hope is it clear....
andrea
If the weight don't move, how it should generate energy? Thank you.
lupenterzo
Weight is for me only a "force maker". I can belive it will move with high pressure too. Cause pressure is different in both the cases. On cilinder with an hole and on the "without". I repeat,my doubt is if the flexible tube will pull the container on the right.Down.If it is so,system doesn't work.But is so? Is the flexible tube pulling down the container it is atached to?Thank you
