Interesting experiment with Meyer's type cell.
Started by Bruce_TPU, May 05, 2007, 01:55:56 PM
Bruce_TPU
Thank you pese!
Okay, last night after work I ran two simple experiments.  I wanted to know for sure that my eyes were not playing tricks on me.
Experiment #1
1 water fuel cell with a dc switched voltage supply (1vdc-12vdc).
Sound frequency from laptop set at the highest, 20K hz. to an underwater speaker
volts 2.666
Amps .96
total power 2.5 watts
Gas produced in 1 minute, using a stopwatch
12.5 ml
Faraday efficiency 78%
2.78 w/lph
unity is 2.16 w/lph
Experiment #2
NO sound frequency applied
volts 2.6
Amps 1.04
Power 2.71 watts
Gas produced in 1 minute = 6 ml
To date, using a Meyers type cell, the best efficiency I have ever obtained was 55% efficiency.  (2.16/my watts to produce liter per hour = efficiency percentage)
Conclusion of first set of experiments:
Sound Frequency DOUBLED production.
My next set of experiments will be with much higher current.
Thank you for your time,
Bruce
Paul-R
Quote from: pese on May 06, 2007, 10:53:33 AM
Quote from: Paul-R on May 06, 2007, 09:49:37 AM
John Worrell Keely reckoned on 42.8 Mhz as a crucial
frequency. Miles out of the range of a sound card,
obviously. But there will be an octave lower down that
will be worth trying, to be found by halving the frequency
repeatedly:
http://peswiki.com/index.php/PowerPedia:John_Keely
Are you sure that you are not simply shaking the bubbles
off the plates?
Paul.
Give attention on the frequency !!
Peswiki say:
Exploding water with 42712.2Hz
This are : 42,72122 Khz   !!!
You can (double? or) triple the frequnzy from soundcard
PESE
If you halve the frequency 14 times, i.e. go down 14 octaves,
you are at C on the piano or on the first fret on the fifth string
of a guitar. Keely might have suggested 261 herz as a place to
start using a sound card.
http://www.phy.mtu.edu/~suits/notefreqs.html
Paul.
TheOne
a good sound card can be able to do 48 and 96kHz but the onboard from computer are usually able to do up to 44.1khz
