Ibpointless2 Crystal Cells
triffid
A curious thing,do your cells get stronger when you step away?   http://www.youtube.com/watch?v=_tb2IRGXf8o&feature=related
Your body has bioelectric fields around it.Now I ask you do you feel tired around your cells? Even sometimes?triffid
triffid
Another curious thing is induction.This is a simple one to one ratio transformer but wrap more than one turn for the secondary you get higher voltage for very little cost.   http://www.youtube.com/watch?feature=endscreen&NR=1&v=AaYOph1I3uw  triffid
triffid
Last Night I hooked up in series three of my cells producing 1.03 volts and got 3.00 volts.These were my tin can lid/mg cells and ran an LED off of it all night.In the morning  the voltage tested at about 2.25 volts.In the morning most of those cells are not producing 1.03 volts..
I bought paper clips to use as cheap connectors.I plan to use the copper wires out of old cords to make connections.Old cords are made of many strands of copper wire.Thin but they should carry the weak currents of these glue cells ok.Black electrical tape might help tighten connections?triffid
triffid
Two years ago when I finally retired I wanted to make solar panels out of solar cells.I spent $1000 on buying solar cells from Ebay.Once I bought all of those(about enough for ten panels) I realized a full half of that $1000 went for shipping and handling($500).So I stopped buying solar cells thinking there had to be a better way.Here with the glue power cells I can buy most of my materials in the grocery stores where everyone has shared the cost of shipping and handling with me already.Hence My mindset towards turning these things into panels.I want to build rock cell panels now.They don't need sunlight.They run day and night.With that in mind I realized Im not where I want to be.One panel the cells dont add up properly.Maybe a chemical is leached from the cardboard(of the 30 count egg cartons) when the cells are wet?Adding resistance to the cells that I do not want? The tin can lid/mg cells added up great last night.Three one volt cells added up to three volts.They did not touch cardboard when they were drying.triffid
triffid
In the future I plan to solder connections where I can.I cant solder magnesium without starting a fire.The tin can lids can take solder If I cut a strip of it and push it to the side without breaking it off. triffid
