Ibpointless2 Crystal Cells
0 Members and 996 Guests are viewing this topic.
triffid
I put together the 18 cell panel so now its drying.I tested the old tin can lid/mg cell I recharged by heating up.It was reading .98 volts.The one I burned up is reading like .005 to.000 volts.The only way I will recharge anymore cells will be in a hot car in the summertime.Make note to self check egg carton for holes.I have four cells in front leaking glue.On newspaper now.triffid
jbignes5
Let me ask a very good question here. When you put these cells in series isn't that like charging them?
This is why they degrade! Putting them in series will kill these cells. So at best we will still be able to change our voltage up to a higher voltage, if need be, like the oscillators do. But that also lessens the current available. The loads will not be willy nilly cobbled together. They should be tuned resonant loads that is specifically designed for that cell...
If these crystal cells are picking up a frequency it must be a radiative type going from our connection from space to our connection in our planet. This is what gravity is.. This steady pressure keeps us bound to the ground by giving our matter something to resist. The direction must be inwards. This is also what we are creating in our cells. Well the circular ones at least. This seems to be amplifying the voltage potential of the inner electrode. This gives it a higher voltage potential then it would have if it sits in air and hence the higher current. Magnesium is a key component. Graphite or copper seem to be the best conductor.
So where do we go from here. Well interfacing nano tech might be a key here. Highly controllable local building of nano structures to increase surface area of both electrodes and even control oxidation levels. The oxide layers have proven to be a great tool in protecting the electrode from the electrolyte and this area needs to be explored more. This way the water issue is solved and hopefully all gasses are kept to a minimum. I suspect crystalline water resists oxidation and conversion to hydrogen because they are bound strongly to a larger extent. Remember that lab grown crystals would be much more pure and error free when compared to impurities using non lab qualified materials. I suspect some pressure would also increase the capabilities of these new crystals to grow.
As I am thinking about the crystals what if they are only wicks that suck up the water and it spreads over the surface of the crystal faces and dries on to form additional structural mass in layers. That would mean oxygen might be required in the formation stage of both crystals. The oxides and the electrolyte. Then they would meet and form natural connections. Hmmm...
triffid
triffid
Let me say that my best cells are the ones not stirred.My best cells are layered.If hooking them up in series  kills them then I will soon know.To find out that silicon has a repulsive push against other matter has totally blown me away.If silicon generates what is called the dark force.Causing the universe to expand more and more.Then that means silicon is everywhere in the universe.If I can use silica(a form of silicon) to keep my casimir plates open longer.Then I can get more power from my cells for longer periods of time.triffid
In the cells without silica the plates keep being pushed together until they meet.When the plates meet then no more electricity is generated and the voltages die out.But as mentioned somewhere only a slight force is required to keep the plates apart.In the case of two ships only a man in a rowboat could keep the two ships apart.I think I posted that already.
triffid
Also geometry of the plates can keep them open forever.Two flat plates coming together will stop the flow of energy .But make one plate a sphere and you see that theres always open space between the plates . Instead of II you have IO.triffid
