Harmonic Oscillating Power Electric generator video
Started by hartiberlin, June 27, 2005, 07:37:55 AM
Hi Stefan,
    I would like to share information on all of this with the OverUnity forum but have not been able to post there lately. If you don't mind I was wondering if you could post the message below under the topic "HOPE Generator". If you want to file it in the solid state set-up catagory that is fine with me. Sorry for the hassle Stefan, I don't know for sure what the problem is there but I have a fairly good idea and its nothing new.
Thank you Stefan.
Jim
Hello Group,
I am starting a new conversation under the topic heading "HOPE Generator" so we can keep things in order a little easier. For those of you who have not seen the short video, do not have the instructions manual, or are perhaps not even aware of what the HOPE Generator is you now have the opportunity to find out and obtain whatever information you want.
The HOPE Generator is a completely solid state device which converts resonant frequencies directly into electricity in the form of alternating current (AC). Various geographic locations will determine the prime resonant frequencies that will allow the HOPE unit to operate at its optimum potential. The short video which is available on this forum was created several months ago and is footage of the first unit that was built. The current assembly instructions will allow builders to replicate the original HOPE Generator viewed in the video. There have been a few changes in the last several months having to do with the construction and configuration of the newer model which have proven to boost the output potential by a good margin. There is also more advanced information which can be made available by signing a short non-disclosure document for now and anyone who is truely interested can contact me at (JFauble@sbcglobal.net) for more information. The current input to output ratios of the HOPE Generator are more than 600 to 1 at the moment and more work is being done daily to continue to improve these ratios. I am now looking for serious minded people who truely desire to make this technology available to the world and need help to do this. This technology has fantastic potential but needs to be developed further. It is actually very simple to assemble and not at all complex in comparison to many of the others which are also less productive as far as energy ratios are concerned. If you have any questions please make sure to look over my previous posts so that I am not only repeating myself over and over again. This will help to familiarize you with what is going on and will enable us to make more progress that much sooner. I belive that the HOPE has already proven that OU is possible and we can take it much-much further with the right help.
Best Regards,
James D. Fauble
Kator01
Jim,
will you post here the new design of HOPE without magnets ?
Kator01
BushWacker
Hello Kator,
? ? Thats an easy one to answer. Just remove the magnets from the unit and there you go! Until I had been able to conduct sufficient tests to convince me that I really had something here and had time to apply for an international patent I did not want to let that little trinket out to the general public. I believe that Arinaya is right concerning the golden ratios theory and that there seems to be a fair amount of evidence to show this may be in part responsible for what we are seeing here. One thing to note is that when using a transformer in conjunction with a HOPE Generator it not only changes the optimum frequency range but almost always expands that specific range. Mass has a lot to do with things as well, and if you add or subtract any mass which is connected with any part of the wiring configuration it will change the optimum operating range also. The new unit I built is not connected with any transformer and runs off of the mini-amplifier which is sold at Radio Shack here in the U.S.. Last night I disassembled the first unit and rewound the output coils with 5 seperate layers of Tesla wire. I am no longer using any magnets what-so-ever and have found that the only purpose if any that they serve is to cause the unit to humm or buzz louder. There is absolutely no increase or reduction in the output potential without the magnets installed and therefore as Arinaya has stated, "there is something else going on". I personally believe that the golden ratios or "sacred geometry" etc.., is only part of the answer, and that there is also a kind of piezo effect occuring as a result of the internal ringing of the molecular/atomic structures in the material composite of both the core and also the wire coils. The total mass of a particular configuration also helps to dictate the prime frequency range which a particular unit will operate at. Also, don't forget the discovery that the geological location also has its effect on the optimum frequency range for a given area. What does this tell us guy's? This is just a guess of course but at this time I am thinking that a lot of what Bearden has said is in fact occuring here. I think that it is more visible with the HOPE than it appeared to be with his MEG unit because we are dealing with a more subtle form of energy being input into the HOPE. However if you leave the magnets installed in the HOPE Generator you will not see the obvious changes that you will if you use sound as the resonant input source. Besides the piezo like effect which I believe is occuring initially as a result of the induction by sound it seems possible that by tuning the harmonic reaction within the core we are somehow tapping into the ZPE field. One engineer that I know believes very strongly that there is what he calls phonon activity going on inside the core which he describes as subatomic particles resembling photons but able to move through matter unlike photons. He believes that the exitation of these particles causes them to bounce around similarly to photons in a gas laser, and that these phonons collide with surrounding particles knocking loose electrons from their natural valance's/orbit's. In turn these atoms become unstable and seek equilibrium and draw from the ZPE field. Intersting theory eh? Whatever is happening guys it is easy to reproduce on a constant basis and in my opinion deserves further investigation. The latest measurements of the second HOPE unit were taken by a person who was initially a complete skeptic about my claims. I let him do whatever he wanted to do with the HOPE and he is now a devoted believer! He is now very exited about building his own unit and I have volunteered to help him custom build it to his specifications. I'm not claiming free energy here people, but I've been working in this field for 33+ years to date and have never seen anything as promising as this. I was told recently that it did not require any real power to light fluorescent lights, and that the real test would be if I could light something like xenon bulbs. Well, guess what? The HOPE has no problem lighting xenon bulbs as well. I have also recently plugged a typical 120vAC to 12vDC converter into the HOPE and tuned the audio frequency to both a 60Hz square wave and a sine wave to see if I could run a small DC motor. Guess what guys? It will run all the small DC motors I have even though 60Hz is nowhere near the optimum operating range of the HOPE unit. The audio source was also provided from the crappy sound card in my newer HP Pavilion which is about the worst I've ever heard. Another thing I have found recently is that the quality and/or purity of the tone/frequency makes almost as much difference in output potential as the level of volume/dB's. The skeptics measurements told him that there was a maximum of .50 watts being input to the new HOPE unit and that there was 268 watts coming out at the terminals. The measurement on his Fluke true RMS MM was 122vAC at more than 2.5A of output potential. This is confirmed by the fact that the maximum output of the mini-amplifier circuit from Radio Shack is .50 watts. While a true RMS MM will show the steady voltage a regular MM will show the maximum voltage readings which are exactly 600vAC. These measurements were made without any additional transformers or circuits being connected. Considering the pitiful output of the Radio Shack Mini-Amplifier and the fact that the volume level comes no where near the critical saturation point which I have observed during tests conducted at home it seems obvious to me that another .5 watts might be enough to kill a person. If you don't believe me follow the instructions and build your own unit and try to hold on to the output terminals if you can, lol. There will always be the skeptics but I have a cure for them here. They are always shocked to find out the truth for themselves with this baby, literally!
Best Regards All,
Jim
Hi Jim,
can you run brightly a standard 100 Watts incandescent bulb with it ?
If you can do that from the output of a soundcard,
then indeed you have something.
Could you show this on a video ?
Regards, Stefan.
Kator01
Hello folks,
I agree on what stephan says.
I have a few extra questions to Bushwalker and people here in Germany,
1) Does any german guy know what the diameter in mm  of 24-26 ( sec & prim-pair) ,27, 29 etc gauge wire is ?
2) What is right- or left-channel bare ?  Mass-Connection ? When I look a my Audio-Plugs I see only 1 Mass, 1 Left (red) and Right (white), that is tree three wires at all
3) Step 14 :
If for example winding-direction of a 1 set of primary is left to right, is it critical if feed-in-connection for AC is at the left side of coil instead right as in the layout ?
Are Right Channel-Bare and Left Channel white necessary for function  in this configuration ?
   They dont lead anywhere.
To Bushwalker :
1) Did you triy to feed in pink noise ( audio noise up to 20 KHz )
Energy of noise is mathematically calculated as beeing of infinite value because number of existing frequencies in noise is infinite ?
2) If you have an output of AC 120 V,  2.5 Ampere, why not simply connect a conventional 100 or 200 Watt incandescent-Bulb and proof to community by simple digi-picture ?
This is more convincing than rms-measurements, because you do not know if you have Equal frequency in output as the input-frequency. It could be that you feed in 60 Hz and have higher frequency ( beyond 100 Hz ) output. In this case your Digi-Mulimerter fails.
I personally do measurements with scope across a low-value power-resistor( or bulb which has 40 to 80 Ohm inner resistance)
Then you will measure the hard facts. A incandescent bulb described above would do this
I give you here an example, of what happended to me lately :
I have a digi-power-meter ( from a electronic-profil-Lab ). It measures actual Power, reactance, phase shift, Voltage, current etc.
Now I was feeding a AC to AC transformer 230 V to 60 V. With this 60 Volt  I fed in half-wave AC ( via one diode and one 1 Ohm-power restistor in series) into a primary of a flyback configuration.
My powermeter  at the AC-AC-Transformer indicated 60 Watt while I measured 0.85 Ampere Input-Current to flyback primary with a RMS-Digimeter. When checking with the scope across the 1 Ohm-Resitor I saw the expected half-wave-Sinus-puls 60 Volt peak. This could be maximum of 33 Watt !.
So I measured then 28 Volt true-rms-Voltage across the 1 Ohm with Digimenter
( confirmed by analogue-meter ). An this gave then 28 V x 0.85 A = 23.8 Watt !!
So even profi-lab-instrument have software-errors because thy assume you only
use fullwave-AC. It is even getting worse when you have higher frequencies superimposed as I would expect tjhis to happen in the HOPE-Device.
I call this the measurement-nightmare of which every electronic profi knows about.
So it is my strong advice to do hard testing on a low Ohm-Load.
3)   Last Question : How did you get this idea of wiring-configuration ? I assume you had access to some data which are not public. This strange wiring-configuration  resembles a complicated band-filter-coupling which is used in high frequency. A normal layman or even specialist cannot get close to such a design by simple trial and error.
Best Regards
Kator
