Ibpointless2 Crystal Cells
triffid
It occurred to me tonight that I had the means to answer my own question.So I took aluminum foil and aluminum foil again with a dried crystal impregnated paper between them likewise with the copper pennies.Both times I could not get voltages higher than .010 volts.But use the copper and aluminum foil as intended and I could quickly get .020 volts or more(with pressure).Very interesting that the crystal responds best to the electrodes it was formed with.Remember these papers are loose and dry to the human eye.Interesting too that I could get any voltage with the same two metals.triffid
triffid
I checked the voltages on my new citric acid/vitamin C cells.Each one reads at 1.38 volts and about 1.3mAs.There is one that reads at 1.43 volts but amps are the same.I plan on sealing them with wax in the next couple of days.triffid
triffid
IB2,going back to what you said about john Bedini  you said,  I really want to see the one where they add [color=rgb(0, 0, 255) !important]water[/color] to a green pellet and it turns into gasoline..I had heard before that that green pellet,powder came from coal.Back about 1991 I learned that hydrogen peroxide could be made from adding a superoxide to water.I spent a few years believing this was what it was all about.Then I heard the powder was made from coal.You can look up Anafuel on the web but water is not mentioned on their websites.Not as a main ingredient that is.hydrogen peroxide is a rocket fuel when its pure enough(90 percent or more).What you can buy in the store is only 3 percent.triffid
PhiChaser
Hey all,
Still testing/measuring stuff. I will post more when I have time.
@ PB regarding the Durham's: It is not very porous at all if used just by itself. Seems like the alum makes it puff up/bubble a LOT more than the epsom does. Durham's is a fine powdery mix; Looks like smooth pudding before it sets up.
Some things that should have been posted a few days ago:
With multiple cells I can get amperage readings between ANY of the electrodes except two opposite poles on side by side cells. I can take those microamps from almost anywhere!! When I take them from the ends (where the VOM measurements are taken) the voltage takes a big nose dive. I will try to take some pictures (or maybe draw some pictures?) of what I mean. It is something (I think) to keep in mind, regarding the dipole.  :D
Also I had an epiphany a couple days ago:
Since my cells have an 'open' electrolyte, I was thinking that they would produce more vA if they were sitting in/on a bed on fine silica sand!! Any ideas on this, it seems like something definitely worth trying...
I've got all these meters that have been cluttering up the place (more coming in weekly it seems! ;) ) so I'm going to build a test 'box' to house them in; You know, a bunch of meters in a (metal?) cabinet with places for leads to plug into. Any tips, ideas regarding this let me know eh? Currently looking at housing 10-12 meters...
Anyhow, the weekend is here so enjoy it, and keep up the great work guys!
Happy experimenting,
PC
ibpointless2
Quote from: triffid on March 25, 2012, 09:35:39 AM
Interesting, never thought about it like that. If you add a extra oxygen molecule to water than you get hydrogen peroxide, maybe they're adding something that gives water its extra oxygen?
