magnet-gravity wheel
Started by FreeEnergy, March 27, 2006, 11:51:18 PM
FreeEnergy
Quote from: Low-Q on May 21, 2007, 02:34:20 PM
Quote from: FreeEnergy on May 21, 2007, 05:26:11 AM
i think i have said this before but, the kinetic energy of arm C can be used to block arm A's sticky spot. well not completely block it, but decrease the magnetic field to some degree.
peace
I have then a few questions:
Where do the kinetic energy come from?
How much kinetic energy is present in the time when shielding?
How much will the shielding process brake the rotation?
If the kinetic energy come from the device itself, the kinetic energy is already limited by the forces which made it. In theory, the counter force which occurs when shielding, plus loss, is probably the same or more than the forces which made the kinetic energy available in the first place. So it will stop. I assume you're talking about the arms in the first drawings you made.
Br.
Vidar
i already explained this i think, i'll explain again :)
when arm A is lifted by the smot the whole wheel turns to the right, then arm C slides to the right causing leverage weight. do you see? when arm C slides we can use this kinetic energy to block the sticky spot (arm A).
i don't have the mechanism for this yet but i know it's possible.
peace
FreeEnergy
Quote from: FreeEnergy on April 12, 2007, 04:47:20 AM
at the sticky point you will have twice (arm C and D) the weight going against the sticky point.
i was wrong about this part. the weight comes from the sliding (kinetic energy) of arm C only. and i think the smot will provide enough momentum for arm C to slide. has to be a one way wheel.
FreeEnergy
had another idea.
when arm C slides not only it can block the sticky spot but i think you could also have water pumped insided arm D somehow...and when arm D is at the beginning of the smot the water gets dumped out. make sense? :)
peace
