Ibpointless2 Crystal Cells
triffid
No mention in the database, of percentage of oxalic acid in BKF however,I was hoping to find out.As I was going through pages of this thread.I realized a few things.Unless you do keep a notebook handy to record your results you do forget things.I forgot I nearly got 2 mAs of current from vitamin C/citric acid cells.I raced off to oxalic acid mostly because I found a free source of it out in the front yard.
Protecting the magnesium strips became a big deal with me when I discovered the vitamin C would snap them after a month.
If treatment with borax can protect the magnesium strips.Then I can go back to vitamin C/citric acid cells.I reviewed some videos last night
And it was mentioned that the different( metal) electrodes create a dipole(potential difference) but the crystals provide the amps.So knowing that heat is a vibration just like sound.Heat does have a much smaller vibration.I am still looking for a better electrode.Gold I guess or titanium? triffid
triffid
Because I went back to page 50 of this thread and worked my way forward to page 61. I was reminded of a few things.
Big J ,said that 2.0 volts is the top voltage for these cells because water breaks down into hydrogen and oxygen.
With my sponge and tap water I can get 1.75 volts for pencil lead and magnesium strip electrodes.So maybe I have found the cheapest electrodes I can get my hands on?With conductive string I can tie the pencil lead in series.Pencil lead, being brittle, has been a problem to hook up to other electrodes.So going back to vitamin C/citric acid cells and using treated magnesium(with borax) strips and pencil leads
should give me over 1 mAs in power? So 30 cells hooked up in series would be 30 x 1.5 volts x 1.25 mAs would give me 56.25 milliwatts.
So in 30 days time that would give me 5040 hours(30 day month)x56.25 mW equals 283.5 watts for 30 days. 12 months x283.5 watts equals 3,402 watts for a year.So I could make 3.4 kilowatts a year.Thats where we are today.At 11 cents a kilowatt.Not even 50 cents worth of electricity.triffid
I guess the next thing to do is work on the crystal mix?Should I add alum to the epson salts?Or ferrous oxalate?
triffid
An article on the efficiency of solar cells, http://onlinelibrary.wiley.com/doi/10.1002/pip.1021/pdf  36 percent tops plus 41.3 percent was once sighted. triffid
I believe 1905 was the first time the photoelectric effect was described?
The cheapest solar cells Ive seen so far are at www.ecrater.com  Some have free shipping,not all,you have to pay attention.
triffid
I think the borax treated magnesium strips are going to hold.Two more days to the two week timeline and they are still firm,not weakened,by the oxalic acid from the dandelion leaf.Unlike the untreated magnesium strips of the past.triffid
30 minutes in a warm tap water saturated borax solution(they turn black during this time).Dry overnight.But I did wait two weeks to use them.
triffid
IBP,John Bedini is mentioned here. http://newalternativeelectricalpower.com/energysuppression.html.triffid
Also a water to gasoline guy is mentioned here.
