Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
Started by Pirate88179, June 27, 2009, 04:41:28 AM
0 Members and 127 Guests are viewing this topic.
andrea76
Quote from: stivep on July 02, 2012, 11:21:22 AM
Can you help me to evaluate this question:
Where is the ground wire in picture below?
Can you find more  about this event?
Wesley
probably the ground wire is not required.see the video below at min 55:06.............http://www.youtube.com/watch?v=Goq76CQapyI
forest
Сергей В.
Quote from: stivep on July 01, 2012, 09:44:36 PM
For your entertainment USA ARMY PLAYING with Anti gravity and Teleportation and STARGATE
Not only with Teleportation and Anti gravity but which is more dangerous for our planet and mankind with Anti matter !!
New USA ARMY toy (stolen from Aliens ....)
Crystal Rectangle Particle Vacuum Enhanced Energy Device pentagen covalent bond reactor
Top secret private Pentagon's military sector acquired extra-terrestrial exchange program known as Crystal Rectangle Particle Vacuum Enhanced Energy Device pentagen covalent bond reactor.
Covalent bond is a kind of chemical bond which forms when electrons are shared between two atoms, so each atom contributes electron to form a pair of electrons that both atoms share to attain a lower state of energy, 2 pentagen atoms forming a covalent bond results in an excess of energy.
Since 1956, many experiments were conducted using the extra-terrestrial PVEED device. Most of the top scret experiments were conducted by Los Alamos as a contractor for the US Department of Energy.
PVEED device has this specifications: The dimensions 26cm x 17cm x 2.5cm. The PVEED
weighs 728 grams. There are exist minimum two versions of PVEED devices. One has weighed 668 grams and other 728 grams.
There was a secret notation in a high order classified document that read: PVEED-1 (Particle Vacuum Enhanced Energy Device). This would indicate presence of PVEED-2 and high!
Many involved Scientists don't refer to the CRPVEED as a CRPVEED or shortly CR but as a PVEED, or as "The Magic Cube".
A small dot moves around the inside when an energy demand was placed on the PVEED.
Los Alamos's scientists have discovered the substance contained in the dot. The dot was found to be a perfectly rounded particle of charged antimatter. They still don’t understand how this piece of antimatter can remain stable until it is tasked with such a movement. They still don’t understand why once a demand is made to the PVEED the antimatter starts its movement and creates energy. So they have found the PVEED is made of an unknown extra-terrestrial material. But several elements have been detected. One of the materials is similar to carbon, but not exactly like carbon as we know it. Another substance is similar to zinc, but not the same consistency of zinc. D. Nor one scientist can't explain the action of the antimatter and the actions of neutrons that are created and then disappear when the demand is lifted. Also they can't explain why the constant temperature of the extra-terrestrial PVEED is 72 degrees. Even when heat is directed on the PVEED, the temperature remains at 72 degrees.
When an energy demand is placed on the PVEED, it creates a signal, that can be measured at 23.450 MHZ. However, when increased demand is placed on the PVEED the frequency is modulated from 23.45MHz to 46.90MHz or double the original frequency. However, when the demand is reduced, the frequency drops to 1.25KHz, which is a constant frequency when no demand is placed on the PVEED. Regardless of what power demand is placed on the PVEED, the frequency NEVER raises to more than 46.90MHz!
Inside device a small set of squares contains horizontal wires. The wires are similar to tungsten. The wires somehow conduct the energy by bouncing the neutrons off these wires back into the fluid. The small dot bounces against the wire when energy demand is placed on the PVEED. Only certain wires would react or expand when energy demand was placed on the PVEED. Some scientists think that, depending on the demand, only certain wires would expand. Somehow, the energy output would be controlled by the amount of squares used.
The US.Government duplicate of the PVEED device. The US.Government made one in 2001 that actually worked for a very short period of time. The operation was EXTREMELY CLASSIFIED and the device blew up at the Nevada Test Site, injuring and killed many employees.
The timeline for the US.Government's extra-terrestrial PVEED device is as follows:
1947 year: PVEED device found in the second crash site.
1949: Los Alamos scientists first conducted experiments with PVEED. At this time, no one knew what it was. Some scientists thought it was just a window.
1954: Sandia Labs conducted several experiments with the PVEED, but still didn’t know its actual use.
1955: PVEED was lent to Westinghouse for experiments.
1958: PVEED was lent to Corning Glass in an effort to determine its construction material.
1962: PVEED’s first official test conducted at Los Alamos and published in a classified report.
1970: PVEED was determined to be more than a window. The PVEED device was found to fit into a space on the spacecraft. Scientists at Los Alamos determined PVEED was some sort of energy device.
1978: PVEED determined to be a high powered energy device that provided electrical power to the spacecraft.
1982: PVEED was first tested and produced energy.
1987: PVEED was given to E-Systems for extensive testing.
1990: PVEED was proven to be an UNLIMITED ALIEN POWER SYSTEM. The construction and contents of the PVEED was learned. However, no one knew just how it worked.
1998: PVEED project know as The Magic Cube was started in an effort to accelerate the knowledge of the device.
2001: PVEED top secret project, The Magic Cube was transferred from Los Alamos’ Futures Division to its "Special Projects or Section K" division.
2012 Currently, as of September 2002, the PVEED is contained at the Section K division facilities, Los Alamos. The system can generate energy equivalent to a nuclear explosion from a range of up to 350 KTons. Without any damaging radiation. Not x-rays at all.
PVEED system can generate this enormous amount of power, without any residual harmful radiation to any organic entity.
In official science, there are only two basic types of bonds by which atoms form molecules: ionic and covalent bonds. When two hydrogen atoms approach each other, their combined energy becomes lower if they SHARE their electrons. Well with pentagen the energy is MULTIPLIED by the number of atoms that is bonded.
Inside PVEED chamber sit two plates of metal. This chamber is a PERFECT VACUUM. A tube running from one chamber into another pushes a gas inside. A third chamber forces still another gas to enter the first chamber. Los Alamos scientists know that the gases push against two plates of metal cause an ENORMOUS AMOUNT OF ENERGY TO BE CREATED.
Also the metal strips are set perpendicular to each other at exactly 6.54 cm apart. Each metal strip measures 18.45 cm x 9.43cm x 3.46 cm wide. The sides of the strips facing each other contain a unknown shiny metal coating. The opposite sides contain a dull coating. Looking at the metal strips from above, one will notice that another substance is sandwiched between the outer two substances.
Lastly, just before the gases are mixed, there is a form of light that is focused against the outgoing energy. This light is of a visible lower frequency spectrum. According to official theory, a small frequency means a lower energy. However in PVEED system, the lower frequency of light was measured to contain an enormous amount of energy exerted upon this outgoing energy.
ps0.02438: Interestingly "discover" of transistor structure had been connected with first Aliens crash site !! Consonance ?? I don't think so !!
ps0.02439:  The romp kids (USA ARMY !!).
Имя Ñ,,айла:
   Shock Images 2010.zip - 19.8 Mb
   http://oron.com/7539913xdbhv
from USA ARMY ARCHIVE !!
The image below is Nevada test site after "game" with such toy !!
I will disclose all of you one very-very interesting secret of USA ARMY. The main USA ARMY UFO-ALIEN test complex IS NOT a famous Zone51 but is situated under the small town of  SAUSALITO near San Francisco - California !! Don't belive me, just check yourself !! All you need is GPR - Ground Penetrating Radar and many luck !!
Now you know where you can find Alien technology !! ....and many more ....
Shokac
Quote from: frantz on July 02, 2012, 03:20:03 PM
Shorting the capacitors should be few times per second (50 or 60) and in every time we should to see huge spark like in the welder.
Continuous and powerful electric arc.
This is 50 or 60 Hz... Timing is good for freqency. This ars is cca 10 or more Ampers.
My question is, how to put that energy into the existing circuit (220V) without having to increase the voltage?
Maybe we should to compare this idea with TK motor (discs)...
The disc use only for make high voltage, and make adicional curent for motor.
jbignes5
Wesley
Virtual grounds can be used as well Stivep. Remember? The loads base can be used as one virtual ground and the box as the other. You notice it is set up on something. This does two things. One it isolates it from any ground and it acts like one virtual ground well it also goes to show it isn't connected to anything but whats inside the box.
The blue thing is a coil. The wires on top should be the starter wires for battery which also end up as antenna (in and out). Sorry after further review there are two wires going to the load. So they should be a closed loop.
The nikko picture is 3 way ground connection (lower right). This was probably changed to facilitate the 3 phase power output to the motor and also there is a wire going from the closer caps (Not igniter) that has been cut to facilitate the addition of the motor which they probably didn't know they want changed. In the video this was why they were testing everything when the camera man was being talked to. You could see them moving around and checking things as they modified the wiring for the motor.
I'm thinking they were trying to prove the ability for them to transmit the power to people or subscribers of the system. They had already facilitated the generation of the power now all they had to do was prove they could get it to the people without requiring the building of a wired network.
You know it would be very advantageous of them to sell only to Industrial customers and let people share the power with smaller taps that can be sold in stores for residential use. This way they get a major part from Businesses and only sell smaller units to residents for a one time cost.
If we take it one step further it could be they were doing it like I said before. They have created a way to generate from a very dynamics rotating field. Each coil having it's wheels(fields) turned by the bigger field of the emitter coil (Tesla coil).
I do think there are buried caps in those coils now like you have suggested. It should be like I had suggested to Itsu to put the cap internally and directly charge the caps. Not like Itsu was doing. Itsu did prove that we can excite caps into charging via induction. I don't think they run all the way to the bottom though. But I could be wrong since I have not gotten the stuff to test this idea with yet. I'm working on it.
I'm still thinking the oil cap inside of the coils will do the same if not tons better and this might be whats inside of that big blue coil. Like counter twisted coils that screw into each other like my idea. This way we could adjust the capacitance on the fly if we can figure out a way to have sealed bearings around each end of the cap/coil. I'm thinking the wider the better like woopy does so the cap can be much larger in surface and a much wider band we could tune for. Each system that is added to the cap/coil will change the frequency that it needs to tune to. We could also bring computers in to adjust the capacitance automatically and in real time. Well almost in real time. There will be a very tight lag but I assume technology will catch up fast as we evolve this process. Adding reflector coils will allow increasing the intensity of this process as well.
