Mehess Motor
Started by billmehess, April 07, 2006, 01:33:35 AM
tinu
HfH,
Now it?s me the one that I?m missing something from my ?argument??! And by asking fair questions on half a page that?s also too much in comparison with 20 pages posted in advance? Or maybe you think that an OU would be revealed in half a sentence?
How about the claim itself? Where is that ?unknown pulled source? you talk about?! Show it to me/ to us/ if you can see it. And in doing so, please remember that extraordinary claims always require extraordinary proofs!
The math may be wrong but it?s not mine and it?s all we (?humanity?, if you like) have for now. In fact, I have conducted similar experiments, like I said, and the math &physics stand. I?ll conduct some more exp and I?ll post the results here, if this is your greatest wish but for now let?s wait for more details and proofs.
Finally, why do I care? I care because if I didn?t I wouldn?t be here. It?s over-unity, remember?
I care because if one experiments in its garage it doesn't affect me at all. If he/she is posting about it, it doesn?t affect me either. But when it comes about claiming OU, that?s a completely different story! I also care because if a device like this is to be marketed in any way and it fizzles, I don?t want to live knowing that I was part of the story, by simply staying silence. And no offence to Bill but he is marketing his idea a lot, although his device is in a very incipient state and not proved to work at all to the very present neither to show, imho, many promises for the future. Current status is ?I will succeed. Bill?.
Tropes,
Many, many thanks for your fair understanding and support. I?ll surely respond to Bill and hopefully everyone will find the final outcome. For know, I don?t see other appropriate language but that of figures? unless one is expecting to watch a video of 30 days ;)
Great forum, everyone!
Have a nice day,
Tinu
Low-Q
Quote from: billmehess on April 10, 2006, 12:52:52 AM
Its Sunday night 9:15 Pm PST, I just got home and ready the replies on the site.
So here goes:
I believe that the answer to a working magnetic motor is the ability to utilize a power source to run the motor. I do not believe that a magnetic motor will run by itself. This is like trying to grab your shoes and lift yourself off the ground. Does it not strike all of us as strange that NO ONE has been able to build such a motor. I do not believe the Snyder or Argentine motor will work. I saw the Synder video like everyone else how hard is it to attach the motor to a stationary platform and see it work on its own?
Butch, I know you are shaking your head now, and I have the utmost respect for you as does I am sure
everyone else in the community but until I see a working Synder or any other motor I simply cannot
except it as a working device. If I am proven to be wrong -so be it, its ok but I am a real nuts and bolts person I simply want to see a real working device.
Enough of that
What I have in my motor is a way to create a electric current by passing a permanent magnet in and out of a coil. This is certainly not new and I do not claim it to be, Faraday is well understood.
The problem is how to keep this motor continuously running. For this I am using the back and forth motion caused by a pendulum from a mechanical movement of a clock.
Its so simple
With this process I can generate current for up to 31 days using a 31 day movement. I am currently using a 8 day movement. During that 31 days I will be storing the output via capacitors or work to directly trickle charge a rechargable battery.
Think of each permanent magnet moving in and out of a coil as one (1) power unit producing over a 31 day period x amount of energy. The more of these power units I have working the more output will result. Remember each unit is really totally independent of each other so "stringing" these together and connecting them in series will produce any voltage I need its only dependent on the number of units in use.
Its so simple
As far as re-energizing the movement to cause the device to continue to operate I need only to store enough power to turn a motor for under 10 seconds which will begin the 31 day cycle all over again.
Tomorrow I will begin building the next upgrade model will the n-45 2in in diamenter 1 inch long magnets I have which will be moving in and out of larger coils. The 2 magnets I am using now, and that show in the video are only 3/8' wide by 1/2". The greater amount of current that will be produced with the stronger magnets will be dramatic.
I can produce enough flow to in 31 days rewind the movement as well a plenty left over to light a bulb.
Talk is cheap I HAVE NO DOUBT that I can do this, after reading this I hope that you can understand how this device works.
Its so simple-
Producing a current continously for up to 31 days= energy
This unit is not area or input specific. It could work anywhere, in a closest, a basement in a cave it makes no difference. It does not require water(Hydro) the sun , wind or any kind of peto fuel to run and it can run continously producing a flow of truely FREE ENERGY.
                                            ITS SO SIMPLY- SEE THE VISION!!!!
REMEMBER!!!!!!
I need only to string as many of the magnet/coil combinations together to achieve the necessary current flow.
This is very important- this unit it generating electricity and the power that is required to run it continously only has to be tapped once a month. All other magnet motors must be providing its own input  from second one. There in lays the problem for that kind of motor. It simply cannot produce more than what it takes to run it-basic law of physics folks.
A clock winded up is nothing more than a mechanical capacitor which you are tapping for energy in very small amounts each day. To "recharge" the spring in this clock requires at least the energy it provided when it was running the pendulums and charging the battery. Using magnets and coils is just an alternative to get this energy out of the spring in the clock - no matter how big magnets and coils you're using. Even if it takes 31 days to get all energy out, before it should rewind itself, the 10 seconds required to rewind it requires as much as approx 270 000 times more energy pr. second, than the energy provided pr second during the 31 days.
So to simplify your device, and even get it more efficient is to forget about all the wires, battery, magnets and coils, and keep the clock only.
Br.
Vidar
hahe
hey group!
wow, what can i say, what a brain you have!  i wish i were smarter .. but i do recognize one thing.  i see mention that, Bill, your invention uses secondary oscillation as per Mr. Milkovic's idea.  This is an incorrect conclusion but of course you did not make it.
Anyway, i just wanted to say thank you for not being a loser (like me), actually pursuing this amazing field and building something!  =D
also i have to disagree with some of the other posts .. and i have credibility here as again, i say i am not the sharpest tack in the box ..
your design merely looks complicated because of the wires.  if i had just a few more brain power i would know much about capacitors and what-not .. but i just do not care =P
okay, enough from this fool
ltseung888
Dear Mr. Bill Mehess,
I posted at this overunity.com forum recently.  Someone referred me to your pendulum device.  I read your information with interest.  Lee Cheung Kin and I (Lawrence Tseung Chun Ning) had our PCT patent application information published on July 27, 2006 (PCT/IB2005/000138).
In our Patent Information, we described how we can extract or Lead Out Gravitational Energy via oscillation of the Pulsed Pendulum.  Some information is available at:
http://www.energyfromair.com/beijing/taiwan2a.htm
I posted heavily in the Steorn.com/forum and forum.go-here.nl under the username ltseung888.  I also posted in this overunity.com forum.  One interesting theoretical thread is:
http://www.overunity.com/index.php/topic,2794.0.html
Some of our discussion backup material with the PCT Patent Office has been regrouped together in this thread (Thanks to Grumpy) as the file pendulum_OU.zip (613.23 KB):
http://www.overunity.com/index.php/topic,919.msg17891.html#msg17891
I look forward to working with you as your device directly confirms our theory.  We helped a Chinese Inventor, Mr. Wang Shum Ho to explain and demonstrate his invention in front of 5 Chinese Officials on January 15, 2007.  Mr. Wang is now a vice president of General Magnetic, a RMB 13 billion Company.
Best regards,
Lawrence Tseung &
Lee Cheung Kin (who cannot read or write English)
