Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
Started by Pirate88179, June 27, 2009, 04:41:28 AM
Shokac
Quote from: Frederic2k1 on August 23, 2012, 02:15:28 AM
Das einzige Problem ist das Tuning, denn selbst wenn man seine Hand mal unglücklich bewegt, ist der Resonanzeffekt kaputt. Kapanadze hat es halt irgendwie geschafft, dass die Last keinen Einfluss auf die Resonanz im Innern nimmt.
Spark gap is use for automatic change frenquency in RLC circuit. Spark gap make resonance!!
Because of this, TK use HIGH Voltage. With small voltage no spark!
a.king21
Hoppy:  OK maybe you're serious. I'll look at some other shots of the wire. I can assure you that is not the trick. The device was handled many times (and moved around) as well as stared at for 4 and a half hours with 3 of the team very sceptical indeed.
Re the braid.
I do not think it is used as an exact counterweight device. In the build two different coloured braids are roughly tied together.
This proved the point:
1 Kapanadze was struggling to find coax.
2 Different braids do not affect the principle of operation of the device.
3 Braid is very important for his device to work.
4 Possible uses:
A Electrical shielding - thus proving he uses high frequencies and possibly high voltages.
B His device is susceptible to interference from electrical storms - maybe earth, maybe air.
C It is possible he uses braid to make a ... COIL - CAPACITOR!!!
C2 Maybe the coil - capacitor has two different widths to it to make it a permanent dipole....
D He flattens the braid out. Big mistake Tariel.
E Maybe v8karlo's device would be supercharged if he replaced his coils with flat coils made from braid.
F It is equally possible that Kapanadze needs the central wire from the co-ax also.
F2 This would indicate radio frequencies.
forest
I have a question about spark gap. In 2004 video TK first looked at spark gap to see if it's working then the other guy switched on bulbs. is the same sequence actions required for this new aquarium device ?
Shokac
Quote from: Zeitmaschine on August 22, 2012, 08:00:41 PM
Kapanadze's little mistake (first one):
But ...
... as in the the 2004 video can be seen (at 20.48), the spark does not fire prior to the start-up of the lamps. What does this mean? a) the high frequency generator has started but high voltage has failed, or b) the high frequency generator itself has failed?
NO. Kapanadze say "Radi, radi" that menas "Working". Spark is fire, but spark is very small. When put load on, fire is strong. This is "Automatic resonance with spark gap".
Test: Use MOT, connect to secundar capacitor (8pF, 2500V) and spark gap in series. Measurement current to primar (2.30A) and measurement current in LC Spark gap circuit. Current is 23Amps.
Jon_sparky
Quote from: a.king21 on August 22, 2012, 10:03:47 PM
Message to Kapanadze:
@a.king21
I would be mad too but how is a threat going to reestablish trust?
Your bis is your bis,
but this is some kind of open source forum space.
To succeed we got to keep moving on and share everything
more or less unconditionally,
including circuits.
That takes trust and how we can bring TKs work into the public domain.
@ v8karlo and a.king21
Can you guys post your circuits please?
I will try to replicate from what I learn here
and we have got a lot more info. now.
If this is truly open source space we can succeed.
Thank you
