Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
Started by Pirate88179, June 27, 2009, 04:41:28 AM
0 Members and 216 Guests are viewing this topic.
sparks
    Tesla was working with the electric potential vector.  Hertz was working with the electric field.  The electric field strength is inversely proportional to the distance from the electron or proton.  The vector potential does not suffer from any losses due to distance.  The magnetic field is the flow of virtual particles that create the polarization of charged mass.  When charged mass moves the virtual particle FLOW must be altered.  This flow is resisted by all flows of virtual particles supporting charged mass throughout the Universe.   When an electron moves it of course alters the magnetic flow.  When an electron is at rest what we see is a permanent magnetic field.  When copper is frozen what appears is a magnetic field forming around the conductor.  In a room temperature conductor the electrons are in constant random motion.  When these constant random motions become ordered low and behold a predictable magnetic field arises.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Hoppy
Quote from: jbignes5 on September 17, 2012, 11:05:24 AM
True those examples only showed unity. They were all of the principle of using sharp high voltage spikes to coax the energy back into their devices. The slayer exciter showed the field effects of such a high voltage field and how to extract energy from it. Each example has unique distinct aspects that they focused on. Kapandze is the exception but as everyone is flinging accusations around instead of really replicating it and looking at the devices honestly they instead choose to fling fraud claims which some of this group has become very astute at.
As one of those on this group that has flung an accusation of fraud on the Kapandze device, I am also a person that tries to replicate and am indeed so doing with the Russian Daly device. Given that there is very little to base a replication on with the Kapandze device and that no hard data is available for it, it is little wonder why it has been labelled as a likely fraud. I certainly do not have the time or money to attempt replications of devices based on sparse information and will always first consider the likelihood of fraud until decent build information etc., is forthcoming. IMO, the Kapandze motor generators are likely frauds in that the second and third devices are probably powered from a concealed motor underneath that belt couples to the main axle within one of the bearing block housings. The first motor shows signs of there being an electrical contact on each disc which could pick power up from concealed battery. Having made this assessment, its difficult for me not to think that trickery could have been applied to the TK solid state devices.
Just because a few people look first at possible methods of fraud, it does not follow that those people are necessarily trying to put down all FE claims. I for one have the same passion as others on this forum for finding a means of freeing the world from the oil barons, I just approach FE claims investigation in a different manner
Hoppy
T-1000
http://www.liveinternet.ru/users/edward_lee/post237839624/
КаÑ,ушка
Ð'нуÑ,реннее усÑ,ройсÑ,во, Ñ...оÑ,ел написаÑ,ÑŒ Ñ,рансÑ,,ормаÑ,ора, но как Ñ,о назваÑ,ÑŒ Ñ,рансÑ,,ормаÑ,ором сложно.
1 Ñ,,оÑ,о - общий вид
2-Ñ,,оÑ,о -48 виÑ,ков
3-Ñ,,оÑ,о -59 виÑ,ков
4-Ñ,,оÑ,о -66 виÑ,ков
5-Ñ,,оÑ,о -70 виÑ,ков
ИÑ,ого: верÑ...няя обмоÑ,ка 83 виÑ,ка.
Под ней: коаксиал - 21 виÑ,ок RG50U.(Ñ,,оÑ,о 7, 8)
Под коаксиалом 159 виÑ,ков провода 0,85 мм.(Ñ,,оÑ,о 9,10)
Ð"алее 475 виÑ,ков провода 0,33 (Ñ,,оÑ,о 11,12,13,14)
Coil:
The internal device, wanted to say it is transformer but it is hard to name it as transfomer.
1 photo - general view
2 photo - 48 turns
3 photo - 59 turns
4 photo - 66 turns
5 photo - 70 turns
Total: top coil 83 turns
Under it: coax cable - 21 turns RG50U (photo 7,8)  (translation addition: 50 Ohm computer network cable)
Under coax cable: 159 turns coil, the wire diameter 0,85mm (photo 9, 10)
Next: 475 turns coil, wire diameter 0,33mm (photo 11,12,13,14)
http://img0.liveinternet.ru/images/attach/c/6/91/684/91684490_100_6334.JPG
http://img1.liveinternet.ru/images/attach/c/6/91/684/91684491_100_6335.JPG
http://img0.liveinternet.ru/images/attach/c/6/91/684/91684492_100_6336.JPG
http://img1.liveinternet.ru/images/attach/c/6/91/684/91684493_100_6337.JPG
http://img1.liveinternet.ru/images/attach/c/6/91/684/91684499_100_6338.JPG
http://img1.liveinternet.ru/images/attach/c/6/91/684/91684503_100_6339.JPG
http://img0.liveinternet.ru/images/attach/c/6/91/684/91684508_100_6340.JPG
http://img1.liveinternet.ru/images/attach/c/6/91/684/91684509_100_6341.JPG
http://img0.liveinternet.ru/images/attach/c/6/91/684/91684510_100_6342.JPG
http://img1.liveinternet.ru/images/attach/c/6/91/684/91684511_100_6343.JPG
http://img0.liveinternet.ru/images/attach/c/6/91/684/91684512_100_6344.JPG
http://img0.liveinternet.ru/images/attach/c/6/91/684/91684514_100_6345.JPG
http://img0.liveinternet.ru/images/attach/c/6/91/684/91684516_100_6346.JPG
http://img0.liveinternet.ru/images/attach/c/6/91/684/91684518_100_6347.JPG
http://www.liveinternet.ru/users/edward_lee/post237842919/
"НаÑ,раиваÑ,ÑŒ с подключенным заземлением.
НасÑ,раиваеÑ,ся с помощью генераÑ,ора на TL пуÑ,ем подбора часÑ,оÑ,Ñ‹ и скважносÑ,и.
Tune with Earth ground connection attached.
Gets tunned with help of TL generator when tinkering with frequency and duty cycle.
So all details now, good luck in replication!
verpies
Quote from: Hoppy on September 17, 2012, 11:53:17 AM
I agree, it is just due diligence.
verpies
Quote from: starcruiser on September 17, 2012, 09:11:16 AM
@verpies, if you look at the schematic shown above the B+ rails are at 150v dc, the pulsing circuit uses a 2:1 step up transformer which feeds the coax transmission line, thus the output would be around 500V
I did not notice that 150V rail. Thanks.
Did you mean an air-core 2:1 step-up transformer?   ...or some kind of voltage step-up transformer that does not rely on varying magnetic flux in its ferrimagnetic core?
I do not know of any ferrites that can magnetize and demagnetize in 1ns.  (reciprocally that is 1GHz operating frequency). For example see this or this or this.
