Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
Started by Pirate88179, June 27, 2009, 04:41:28 AM
Pirate88179
At All:
Buzz and Quark are the same guy.  He also posts on this forum under at least 2 other names that I know of.  I apologize for his rude behavior and I will suggest to Stefan that he be Moderated once again.  He thinks using a proxy server makes him bulletproof....well, there are ways around that.
I suggest that folks place him on ignore and get back to the discussion at hand.  He obviously has another agenda.
Thank you,
Bill
27Bubba
Quote from: Pirate88179 on October 25, 2012, 09:18:12 PM
At All:
Thank you,
Bill
He need a medical attention.. Fast!
Zeitmaschine
Quote from: elementSix on October 25, 2012, 07:37:01 PM
Large Russian Transformer >>>>  http://www.youtube.com/watch?v=iFP8zu6TdvI&feature=related
All I see is another guy that keeps the secret for himself because humanity allegedly is to stupid to deserve it. And what I don't see is hovering table saws and transformers due to anti-gravity effects.
SECRETS OF COLD WAR TECHNOLOGY
»Part of this apparatus required the implementation of a very powerful capacitor bank. This capacitor “battery” was charged to very high voltages, and subsequently discharged through short copper bus-bars. The explosive bursts thus obtained produced several coincident phenomena which deeply impressed Tesla, far exceeding the power of any electrical display he had ever seen. These proved to hold an essential secret which he was determined to uncover.«
Quote from: wattsup on October 25, 2012, 07:55:17 PM
Take the 2004 device again. The open transformer secondary with greater amperage then the primary is rectified. Why do you rectify it when your output is AC to load?
To short-circuit the DC?
»This hazardous condition only occurred with the sudden application of high voltage DC. This crown of deadly static charge stood straight out of highly electrified conductors, often seeking ground paths which included workmen and switchboard operators.«
Now what if a capacitor is short-circuited with a frequency of 50Hz? And this discharge shockwave is resonant with the 50Hz AC going through the transformer and the light bulbs?
Interestingly the TK device needs approx. a second to go off, not many minutes.
»Objects placed near this device became powerfully electrified, retaining a singular charge sign for many minutes after the magnetic discharger had been deactivated.«
»The “Dissipation of Electricity”, published just prior to Christmas of 1892, is the pivotal Tesla lecture. This is the departure point in which Tesla abandons research and development of high frequency alternating current. Divorcing himself from that field entirely, Tesla describes the Shockwaves and other effects of IMPULSES.«
The patent 514,168 is filed August 2, 1893, hence it has something to do with »Shockwaves and other effects of IMPULSES«.
Anyway this reading is inspiring ... :)
Jack Noskills
Buzz, I have two questions for you. You imply having a working device, a.king.21 has connections so maybe you could discuss with him so we could all go and buy your device once they start manufacturing in quantities ? Or do you think some idiot might create a weapon out of it by accident ?
Displacement current, I made simple three trafo setup and I got displacement current from it. One primary and two secondaries. Maybe 3 mA went in and about 30 mA came out when connected to ground. So my coils were acting as capacitors, one end unconnected and one end connected to ground. I could connect two secondaries in series and I got more displacement current out. It seemed that I got more displacement current from one end than the other, hot/cold ? But power was low and displacement current did not increase even if I put power through a primary. This makes me think that to get power increase higher frequency and higher voltage signal is needed. Is this correct ?
Farmhand
Wattsup, I don't think it's possible to have an "isolated" Earth stake, the ground is the ground I think.
Only resistance will differ depending on how conductive the ground is.
http://ruralpower.org/swer/swer-how-does-it-work
Cheers
