Probality of God
Started by Newton II, September 14, 2012, 01:33:36 AM
gravityblock
Quote from: eatenbyagrue on November 09, 2012, 09:44:36 PM
I have a little more time now, and let me be more specific.  The video is just an exercise in some backward looking convoluted math to end up at a number you want to end up with.  This is just basically numerology, and we all know what bullshit numerology is.
A good exercise to purge yourself of the idea that this is good evidence is to try to work out the math forwards, without knowing the end number you are trying to get to.   Can you actually use the information presented to make predictions before the event happens, or is the information only good for confirming, through some convoluted logic, an event in the past?
Then please show me how this was done, and how convoluted logic was used to confirm this.  I'll make my case below showing other wise, then you can make your case against it if you can.  Until you or anyone else can make a good case against this, then this must be considered good evidence for the existence of God.
Let's have someone build four new structures on the earth, and create a new unit of measurement to represent the cubit for these four structures being built, then keep hidden what the new units represent. Next, reveal thousands of years later what your new units represent.  Then, thousands of years later after mankind knows what the new units represent, pass into a law another unit of measurement where the new units are converted to the units passed by law where the L*W*H represent two of the structures in diameter of the greater light and two of the structures represent in diameter the lesser light.  The L*W*H is showing an intelligent design of a message intended for a future generation instead of a mere cosmic and earthly coincidence.  Also, tell someone to circle a city a certain amount of times to represent the number of degrees which adds to and equals the diameter of a body in space which mankind didn't know at the time the message was generated, which represents the lesser light.  The numbers of this diameter must be of the same unit of measurement which is passed into the same law thousands of years later which were used for the four structures which were built (this is also showing intelligence behind the message, which can't be called convoluted logic by the process of simple mathematics in order to confirm a message showing intelligence beyond this world).  In addition to this, the city which is circled must have a name with a meaning that represents this body in space (also showing intelligent design behind the message which can't be considered convoluted logic by the process of confirming it).  Then someone uses simple mathematics (the area of the structures) to confirm this intelligent message, and you call it convoluted logic.  If simple mathematics wasn't needed, then you would say the message wasn't by an intelligent being and it was both a cosmic and earthly coincidence.  This may be true for one of the structures, but not with all four structures taken together in addition to the city, and in which had a name representing the same body in space which shadowed two of the structures on earth and one of the bodies in space (the lesser light).  This is showing and confirming an intelligence beyond this world which knew the future in advance and/or who could influence the future, which is beyond both cosmic and earthly coincidence or convoluted logic.  If you are honest with yourself, and really think deep about this, you will see how there is no convoluted logic by the process of itself to confirm a message showing intelligence which was sent from the past to a future generation who both knew and/or controlled the future along with having knowledge of the unknown diameter's of both the sun and moon at the time the message was generated.
Gravock
gravityblock
Daniel 12:4 says, "But you, Daniel, close up and seal the words of the scroll until the time of the end. Many will go here and there to increase knowledge."
Some of the words sealed up in the scroll has already been unsealed from an increase in mankind's knowledge, such as mankind knowing the diameter of the sun and moon.  In the end of days for this system of things, God has provided absolute proof and evidence for his existence and power, so no man can reject Him by saying there was no good evidence for His existence.  It's ironic, how God used the very same science that takes Him out of the equation to prove His existence.  God will catch the wise (those who proclaim to be wise with their ungodly wisdom) in their own craftiness.  He will confuse the wise with the simplest things of this world.
Hebrews 11:1 states, "Now faith is the substance of things hoped for, the evidence of things not seen".  Have faith in this good evidence of God.  He has already provided you with a good foundation to put this good evidence on.
2 Corinthians 6:17 states, "Therefore, come out from among unbelievers, and separate yourselves from them, says the LORD. Don't touch their filthy things, and I will welcome you."  Separate yourself and don't touch or hold onto their ungodly wisdom or any other filthy thing of mankind and God will welcome you as His own.  Yes, ungodly wisdom is a filthy thing to the LORD, which is a trait and a property of the unbelievers.
Gravock
gravityblock
Based on good evidence with absolute proof, the probability of God is 100%!
Gravock
WilbyInebriated
Quote from: gravityblock on November 10, 2012, 11:32:19 AM
Based on good evidence and absolute proof, the probability of God is 100%!
Gravock
you godtards are so silly... ::)
gravityblock
Quote from: WilbyInebriated on November 10, 2012, 11:35:29 AM
In the end, you'll probably be the last one left trying to show how we're silly.  Good luck with that!
Gravock
