new clean efficient alternative energy source
Started by planetenergy, November 14, 2005, 08:05:23 PM
planetenergy
We would like to introduce our technology to overunity.com
and invite you to our websites at:
http://www.planetenergy.com
http://www.terawatt.com
Copyright Ã,© Planetenergy Ltd.
Copyright Ã,© Terawatt
Johannes
FreeEnergy
very nice...
so the springs actually locks/unlocks because of its rotating momentum from gravity and is what gives that extra kick to keep on turning?
im guessing...
Is it permanent magnet based ?
Do you try to rectify the cogging of magnets somehow ?
Regards, Stefan.
planetenergy
Dear FreeEnergy,
We advise you to observe following interactive demonstrations at:
http://www.planetenergy.com/mech15.htm
http://www.planetenergy.com/mech11.htm
and
http://www.planetenergy.com/mech5.htm
It shows,
An arrangement of disks:
  • Interlinked with springs
  • The disks can only rotate in one direction (applied backstopping clutches). http://www.planetenergy.com/in2.htm
  • The rest tension (extended balanced condition) of each spring is higher than the friction in the arrangement (included tightening torque from generator on collector axis).
Therefore:
  • The disks in the stack are positioned at rest symmetrically to each other.
  • Once disturbed (by bursting impulse on 1. element after IPS Loader) the elements (disks) constrain themselve forward until prior symmetric position is again reestablished.
  • As the rest tension of each spring is calculated to be higher than the total friction, friction will only slow down the entire impulse but will not prevent that each spring will reestablish its extended prior state again and again after each initiated impulse.
  • General rule: the rest tension in between two interlinked elements should be 60% higher than
    the total torque in and on the system (friction on backstopping clutches, friction on overrunning clutches, tightening torque on generator...).
Result after each impulse:
  • The position of each disk to each other is exactly equal to its starting position.
  • Each disk has been rotated one after the other (caused by its specific mass moment of inertia) in the new position predetermined by the first element burst.
Target of our first prototype is to establish:
  • The right amout of disks
  • The right weight of each disk (a perfect mass moment of inertia in accordance with the tension of springs results in a high defined impulse)
  • The right rest tension of applied springs (in accordance with the friction in the arrangement and tightening torque of generator)
  • And the right ammount of degrees and speed of the repeated burst initiated by the Impulse Loader
    http://www.planetenergy.com/mech7.htm
  • We established several basic tests in real world.
  • We entered these results into numeric simulations.
The outcome leads us to realize a prototype and overcome Old Believes.
Today we are in process of developing a 30 kW demonstration Unit.
Best Regards
Johannes Schroetter
Note: Old content, please go to our website for recent state!
Copyright?Planetenergy Ltd.
Copyright?Terawatt
Johannes
lltfdaniel1
Now this is a Machine that will , you know ;-).
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
