Floor
First.
Please excuse my interruption into your conversation, if you will.
This is the first time I have logged into O.U.,  I am trying to get attention upon a new electropermanentmagnet motor /generator
design, and I  would very much like for you gentlemen to take a Quick look at the brief attached PDFs. I have filed a provisional patent in the U.S.. I want this design in the public domain !!!  If you think the design has merit, Please ! copy, publish, build, experiment with, use, or sell
the design, as far and wide as you can, and as quickly as you can. I think that it is possible that this innovation could push a conventional high efficiency  DC motor / generator over unity.  I
It is beyond my capacity to get the design out to very many people. I lack both the means and the technical skills to so.
Please view the attached files and if you think, I may right about this, please act swiftly.
Thank you for your time and consideration
              Floor
DeepCut
Hello Floor and welcome :)
I can't understand why the device may be OU, could you provide us with a description of what you think is going on, what is the main concept ?
Thanks,
DC.
Floor
A permanent magnet only motor would be a simple thing to design, if there were a way to rapidly turn permanent magnets on and off, without expending a lot of energy to do so. Electro permanent magnets are sometimes used in lifting cranes, now that we have very powerful "rare earth" magnets.  In these lifting cranes, an electromagnet is used in a magnetic polarity opposite to the permanent magnet, to neutralize the permanent magnet, (in effect, "turning the permanent magnet off"). This prevents the dropping of a pay load in the event of a power failure, and requires power only to release the payload. This however would use too much power to be effective in an electric motor.
Similarly, an electromagnet can be combined with a permanent magnet to create a magnetic field which is stronger than either the electromagnet or the permanent magnet alone. The combination results in an electromagnet which has a magnetic field that is greater than the wattage input alone can produce.
In the design presented, by proximity, (the distance from the other component / elements),  the electro permanent magnets (E P M's)
are in effect"turned off" until the electromagnet elements are energized. When the electromagnet elements are energized, their magnetic
fields will have a percentage of the permanent magnets, magnetic fields added to them.
If a conventional all electromagnet, DC motor or generator of a design, that was of say 91% efficiency, had also this type of E P M integrated into it's design, it would be O U if the E P M's  can contribute 10% to the efficiency. Can they?
          Thanks again for your time
                         Floor
DeepCut
OK that's made it clearer, thanks. I like the sound of it.
Have you built a prototype ?
DC.
synchro1
@Floor,
Art Porter's Magnetic Amplification and Neutralization Generator does exactly that:
http://www.gap-power.com/
