High voltage HHO by IronHead
Started by IronHead, March 08, 2007, 06:19:16 PM
IronHead
This is just a rendering to get the idea of full enclosure  .
This is only one module we are working on  you will have many in a finished system that can then be enclosed . You can  do this one or not  just to see the out come as the production is much higher with and fully enclosed cell.
s_c_engineering
Thanks for the info on the vic.  keep up the good info on the S-cell!!
hkyle
@ironhead
I built a cell a while ago that was similar to this design. The problem that I had was with the water inlet ports at the bottom. When I started making about 3 liters / min the hydroxy would start coming out of the water inlet ports at the bottom of the cell...Thats when I went to a port injection into each cell from the top of each cell. I will post a pic of the water feed system.
Hydroxy comes out the top port and water goes straight in.
It?s easier to be forgiven than it is to get permission....
IronHead
Ok , Your saying the  HHO was back feeding to the  pump to your cell .Not sure how that can happen if there is a constant flow of water pushing into and out of the cell .I have not had this problem. Maybe I should complete the model  with the rest of the chambering, pump, valves and connections so you can see the full  circuit .
This was just a quicky  to show the construction.
Also did you have this setup in a car or under any kind of vacuum?
I am not really sure what I am looking at in you pic
Though I am very interested in how you did your cell
Robb077
You might check the pictures at oupower.com under hydrogen. The man built a series of cells using walmart cereal containers, each has 10 stainless 316 3 x 6 in each. Looks clean and simple. Uses a 2 liter coke bottle for a bubbler. Plenty of pictures and explanations.
