Kapanadze Cousin - DALLY FREE ENERGY
Started by 27Bubba, September 18, 2012, 02:17:22 PM
joaouchoa and 414 Guests are viewing this topic.
NickZ
  Grum:
   It seams that the Chibinidze replication is using one of Akulas diagrams or ideas, and if so, it may help to study previous Akula devices, that lead to the two last ones shown. As the earlier device tests were a bit simpler, and maybe easier to understand how they may have worked.
  Here is one of many previous Akula builds (below), but he does have others that use the spark gap.
I personally am trying to avoid a spark gap, for various reasons that I already mentioned, but if I find that a silent gap, may work, and not disrupt my surrounding electronics, then I'm not against trying it as well.
  Notice how he changes the core windings on this video below, and his use of open ended coils, from one video to the next. It looks like the trim pot(s) is his way of adjusting the frequency, or voltage, or both.
  Your drop down transformer may affect the way that the whole system works, as it's attached to it. Also, do you use a diode, anywhere? Some devices are showing a diode, and some aren't. Which may be an important consideration, as diodes are strange little critters. Also the trim pots may allow you to obtain the sweet spot, that otherwise you may not locate, as resonance and frequency is everything in these devices.
  http://www.youtube.com/watch?v=TA3bg55qQXw
verpies
Quote from: Grumage on May 11, 2013, 12:59:51 PM
Taking your comment further, to me a larger VA rating would in effect create a need for a larger core?
If frequency and core material stay the same then yes.
NickZ
 I am more than slightly confused at what the Akula diagram is indicating, compared to the actual device.
As it shows 25v source input, yet the video is showing a 12 battery, as the input source. Also, the video is showing a feed-back coil going to a big cap and rectifier, which then goes to the inverter that feeds back the system. Yet the diagram shows no such feed back path, which would be important for it to self-run.  Some components are similar, but some aren't.
So, it's all very, very confusing. And has taken more than a little time to try to figure out just how to go about it. Also, as each of his videos shows a different version, different coils, with different, well, everything, it makes the job practically impossible to replicate.   Maybe that was the idea...
  Needless to say, any help is more than appreciated.
Hoppy
Quote from: NickZ on May 11, 2013, 11:11:40 PM
Confusion seems to the name of the game here Nick. The Dally device is the only one I've seen so far that provided good and sufficiently detailed information and photos to attempt a replication. IMO even if the Akula and other devices featured on this thread are genuine, it will be mostly down to a luck as to whether they are replicated into self-runners. If the builders of these devices are genuine in their wish to help mankind free itself from the oil barons and are sitting on a self-runners, bold enough to demonstrate these by video, then surely they should also be bold enough to open source full build details. I attempted a replication of the Dally and Chibinidze devices as did a few others. Although I was unsuccessful in building these as a self-runners, I would be happy to try again with another design but only if the originator took the trouble to provide enough detail to make replication possible.
The genuineness of those people that post badly documented claims of self-runners is highly suspect IMO.
dllabarre
If you listen to Wesley's translation of both of Akula's videos you'd hear Wesley translate Akula saying: I built this for myself and my grandchildren.  He didn't build it for the world or mankind.
Akula's hand drawn schematic and videos, along with Hendershot schematics and video replications (which is what Akula's device is modeled after), is by far more than TK or anyone else has ever provided in order to build your own device.
EXCEPT for Dally.  I believe Dally provided very detailed information, again if you listened to Wesley's translation of Dally's video.  Plus Dally took his coil apart layer by layer to reveal all the windings.
Also, T-1000 taught us several different ways to get more out then in.
Don't bother responding to this post.  I'm taking a leave from this thread.
DonL
