Safe One Wire energy transfer by Serbian inventor Milutin Miletic
Started by hartiberlin, June 16, 2011, 11:51:28 AM
dradak1
Quote from: slotinnn on June 29, 2013, 04:05:44 PM
I have tried this way and doesn t works at all... any configuration any ideea? I have used and coax of TV interior phase the exterior connected to the zero and ground... no transfer of energy .... between the two wires... Seems that the exterior must be the one wire... because it has the zero voltage and allows to touch it... Apart of this I suggest that in the bulb as in the motor put to work you have to connect two wires to the one wire ( the named safety wire).... The system uses the same wire for the go and return energy... and this one wire is connected on the other side with the zero and the ground.....the only probblem is [color=rgb(27, 142, 222) !important]the transfer[/color] of the energy between the phase and the exterior wire.... any other ideeas?
Sorry for misunderstanding - I ment that idea (just concept) is similar as coaxial cable.  :(
slotinnn
Quote from: dradak1 on June 29, 2013, 04:51:14 PM
no problem dradak I ve seen it the same way because the patent say so ... but no result.... any other ideeas? It would be shame for me if with a petent we cannot do it
tadejstenta
I manage to write it in latin - serbian langue.It will take another day or two to translate it in eng.
dradak1
Quote from: tadejstenta on June 29, 2013, 08:38:15 PM
As per MileHigh suggestion - find attached translation - and I briefly checked looks much better that translation from English to Serbian. If you still have questions - fill free to ask.
dradak1
Quote from: dradak1 on June 29, 2013, 09:02:05 PM
Sorry - for those of you who still using pathetic MS Office - here is the .PDF file.  ;D
