Source of energy, Testatika
Started by Lycanthropist, April 13, 2007, 04:01:40 PM
mikewatson
The recent academic paper by Lochak on his discovery of a low mass magnetic monopole could be a good candidate for the source of energy for the Testatika. Lochak's monopole is a magnetically charged neutrino and may be produced by Beta emitters in a magnetic field, either N or S charge. The original paper is in French:-[/font][/font]
                                          [/font][/font]
"The Magnetic monopole is not a Myth"[/font]
It has an equation, experiements and planned applications.[/font]
by Georges Lochak[/font]
Fondation Louis de Broglie 23, rue Marsoulan 75012 Paris[/font]
e-mail: inst.louisdebroglie @ free.fr[/font]
[/font]
Abstract: The magnetic monopole is a particle with a single magnetic charge north or south, not two opposite charges like a magnet. This often regarded as a myth, but it is a reality, there is now a theory, due to the author of these lines, with equations and accurate predictions supported by hundreds of experiments where the result show different possible applications areas such as clean energy, medicine and even space exploration.[/font]
But this is not the monopole that was expected. We expected a heavy particle, and it is a light particle, we expected these barbaric-excuses that it is "a charged boson with strong interactions," while it is in fact it is "a fermion endowed with weak interactions. " But the theory agrees with the experiment, as we show in simple terms.[/font]
Science is woven of endless controversies, clashes between opposing conceptions sometimes end up together, definitive oversights and triumphant resurgence: the monopole Magnetic is no exception. At the time of this writing, looking up the word "monopole" on Google, they say "it is never observed," but the word "Lochak monopole" is cited in articles which sets up another theory, and describes experiments where applications point to the new energy research, medicine and etc. (end of extract).
The Lochak monopole is produced by arcs and sparks as well as by beta emitters in the presence of a north or south magnetic pole.
The effect of radioactive sources on radio reception, so called radium radio intensfier (Bemier "The Electrical Experimenter Oct 1916" has been quoted before) also Hubbard, Hendershot, Moray etc. becomes more understandable, the solution to the problem lies in the up to now undiscovered magnetic monopole.
tim123
Hi Folks,
  I have a shop-bought Wimshurst machine. I was intrigued by the 'UHF transformers' in the Testatika, and I wondered if it somehow generated radio waves... I bought it for my son, and we've both noticed that when we play with it - it kills the TV signal.
So I hooked up some wire to the 'scope, put it near the Wimshurst, and started turning...
I don't know if it's an artifact from the 'scope, but the machine seems to produce a wide variety of high frequency pulses - in all ranges - up to Ghz. Interestingly, some of the pulses persist after the machine has stopped - for a few seconds.
I tried a few time-ranges, and there seems to be a clear repeating pattern.
I need to do more tests, but I thought I'd share & post in the meantime...
Tim
captainfletcher
Hello,
You can follow my early realization of Testatica this address:
http://www.conspirovniscience.com/forum/index.php?showtopic=1361&st=0&#entry35465
I'm almost sure of success, the secret is in the magnets and blocks of Plexiglas.
instead of the wheel, I will use a Very High Voltage Generator.
I expect the supplier of copper sheet.
To be continued ...
P.S.  Sorry if I copied my post from another topic, I saw the topic too late.
John.K1
Sorry guys, I just took a peek in to this section. I do not know about Testatika much But would I be wrong if the basic principle is the Wimshurst machine generating the static electricity, leyden jar as a capacitor and something like Gorey's power tube to generate useful electricity from the sparks?  In the case of using HV transformer it would be like Don Smith device :)  I think the success is in extremely  short pulses.
T-1000
Quote from: John.K1 on September 17, 2013, 02:32:48 PM
Seems you did not read previous posts - http://www.overunity.com/2223/source-of-energy-testatika/msg360205/#msg360205
The secret is in piezzo element which is polarized by magnets and doing secondary emission-like effect under high voltage for injection of free electrons (which means amperes) into high voltage circuit. Then the resulting mix is simple Volts multiplied by amps.
