Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
weri812
@ wcernuska
can you point to that video
would love to see that
@ gk have you fired up that ecd w/ 4 g cable and alum wire frame
if so how did it go
wer
PUT YOUR MIND IN GEAR BEFORE  YOU PUT YOUR MOUTH IN MOTION
Bruce_TPU
Hello All,  :)
My partner and I experimented on the ECD tonight.  Fried a driver to the second frequency almost right off.  I got a picture of sine waves, with two frequencies.  We still have much more to do with our circuit and how we are wired to the ECD.  We did take Jason's advice and are using some very good Coax to input the frequencies to the ECD  (So many wires, so little time!  LOL)
IMPORTANT:
Does anyone realize how important a post, reply #688 was?  It is the EXACT thing I have been saying in my thread.  BEP also.  And if you read carefully there is some interesting information there!  (On a side note, the post after him had too much information.  I could make out watch batteries in the 6" under the tape, but never posted this.  Nor is it in any video.  Nor was the videos released two years ago, if I am not mistaken.)
Quote from: Technoalchemist on July 03, 2007, 10:07:54 PM
Hi all. Great stuff you have here. Congrats. I too believe SM has it, as Tesla and Henry Moray before him. I have watched the videos, read the correspondences, and most of this posting here. I would like to make a few comments regarding SMs' words from the PDF on PESwiki and one video......He does mention earth resonant frequencies. (7.83Hz) He also speaks ALOT about Tesla, and his wacky TV story. I have been getting into "natural radio" (ELF) quite a bit lately. If I understand Schumann resonances and frequency harmonics at all, our "earth-resonant antenna" becomes 31.42' long @ 7.83MHz, or 314' @ 783KHz. I could be wrong. I have read that our 60Hz power system resonates with the Schumann cavity. I believe one of the coils acts as an antenna. Calculating toriod antennas may be different, but I know they are used for satellite. When he said to "never tune to exact frequencies of conversion" I suspected he meant this one. For it also appeared to me that the discord in the other frequencis is where the useable power comes from. The fact that the unit produces RF burns was another clue to me. The gyroscopic effect another. He also mentioned Tesla and "tuned magnetometers" His commentary could also be a bunch of B.S. too. Very good to see Bob Boyce here.
Now I have some questions:
1: Has anybody seen the UEC patents? I think the MPT are rubbish
2: Are you all in concensus that there is a battery in play here?
Its an honor to be here with such an astute group of folks, doing some of the greatest energy research for REAL public good in probably a century. Three words for the experimenters: SAFTEY, SAFTEY, SAFTEY! Don't cook yerself off with these great toys.
This is the answer to what is missing in our ECD, as I have been trying to say!!  I need help on the mechanic, but this IS how it needs to function.  (PLUS all of the other parts, of course.  3 frequencies, opposing, diffent sources, identical, out of phase slightly, etc)
Cheers,
Bruce
HumblePie
Too  much info you say?   Then you tell us you have never heard it and that 'it does not exist'?     Be nice.  I'm new... and I have a great memory for details, but I don't recall 'where' I saw it... It was between Nov '05 and maybe June '06.  It must have been an early video because SM only had one 6" unit and he only powered two 60 Watt Table Lamps.  They seemed dim also, not full brightness, less so after screwing in the 2nd Lamp.  It was filmed in the same looking house from SM's left side from the end of a long folding table and some from accross the table.  The lamps were beyond SM, one on table, 2nd on the floor.  No Lamp Shades!   It was a short video.  He never mentioned Drills or TV's.  I only saw those later vid's here recently, where he had his Invertor to run a drill and TV.
He insterted one camera sized "Button Cell / Watch type battery", thin and US Quarter Dollar sized.  He inserted it into the upper portion from the inside of the ring and the recepticle was slanted 45 degrees towards the middle.  He clearly stated:    "This battery was required to start the process"... I did not hear him say it needed to stay running, but it seemed like it did, unless it primed and then turned itself off.  This is why I've been asking all these questions!
This is why I asked if this thing still requires unbilical to freq' gen's in Reply #664, and again in #676.   I am still reading the posts or I would have realized you guys (or maybe just you) did not know about it.   I took that vague response to #676 question as "No", and kept on reading.  I guess Linsay meant 'Yes... still needs umbilicals'.  I wish GiantKiller was till posting.
Now you all out there, help find this video so the rest of you can see with your own eyes a 'rediscovered' artifact that surely matters!
HumblePie
BTW - Quote from http://www.unexplained-mysteries.com/forum/lofiversion/index.php/t46394.html
"Earth's background base frequency, or "heartbeat," (called Schumann resonance, or SR) is rising dramatically. Though it varies among geographical regions, for decades the overall measurement was 7.8 cycles per second. This was once thought to be a constant; global military communications developed on this frequency. Recent reports set the rate at over 11 cycles, and climbin."
This is because of HAARP ELF replacement technology.  Time is speeding up because of this.  See:  http://www.carnicom.com/time2.htm
So what is the resonance freq' today and what is the deviation so we can all design units that tune the correct frequency?  I see Otto's and Ronnette's pdf and wave forms.  The sinus pieces are displayed at 5uS time base.
Where did they see 'pumping action at Schumann frequency'?  I don't see any time bases set that slow in the video or pdf.
ronotte
@Earl,
In ECD THERE's a MIXER and it's highly non-linear (logical kind mixer): all Mosfet's Drain pins are connected together.... there all the frequencies are indeed mixed and putting a scope probe there (ZERO point) you will see every kind of said by-products they make almost impossible to synch the scope trigger! There you can also appreciate some of the main mixing envelopes as if you select the right scope 'time line' it is possible to appreciate the main produced sum & differences frequencies just looking at the waveforms's envelope.
Roberto
