Reactive power - Reactive Generator research from GotoLuc - discussion thread
Started by hartiberlin, December 12, 2013, 04:34:12 PM
0 Members and 24 Guests are viewing this topic.
d3x0r
So... I would be curious of measurements with the probe on the resistor side of the cap as the voltage for the existing CSR, non inverted vs the differenece across a CSR from power...
to avoid shorting your scope from ground to hot, just move the probe, keep the common... but then the current is inverse, and the current is the difference (a-b) of the probes... which would be nice if you could then have a*(b-a)    // maybe a-b there is a negative... but the voltage would be subtracted from the other side.. and inverted.... so a*(a-b) for power on the AC side...
deslomeslager
Quote from: poynt99 on January 09, 2014, 09:58:00 PM
The second link doesn't seem to work.
Just curious what is there.
Index of /ftp/Overunity.com - Forum members/poynt99
    Parent Directory
    Towards_Realizing_the_TPU_1.1.pdf
    Towards_Realizing_the_TPU_1.2.pdf
    Towards_Realizing_the_TPU_1.3.pdf
    Towards_Realizing_the_TPU_1.4.pdf
Link is fine ;-)
poynt99
You can find those documents (and others of mine as well as other folks') by clicking on "Upload/Download" over to the left under the "Navigation" section of this forum.
cristopalba
Good evening Gentlemen
The world, attending in the debate . You will your succeed or not? That's the question. I personally do not want to get in a dispute (do not speak English), I just want to say that I, at a lower level, I tried without Oscilloscope current probes without alterntive or continue, to put into operation this circuit. How do you like it: https://www.youtube.com/watch?v=mjT6SsRdU_8
Master Luc or Poynt ......
best regards
Turbo
I found these documents to be way too complicated and also incorrect.
Especially this sentence:
'Pulsing directly from a 9V battery isn't going to cut it.'
Is incorect.
So then my question is where upon you base that conclusion.
Have you tried it?
I have.
