Wasif Kahloon's Magnet Motor
Started by NTesla, January 29, 2014, 12:31:49 AM
mscoffman
What is really needed is a mechanical shaft to shaft coupler with a torque
comparator and shaft direction measurement that produces an indicator
arrow display that indicates which direction the torque vector flows to.
It's just too easy to have a generator be a motor or vice versa.
If I where to design a fake it would have two modes. One to make the
magnet part operate unloaded to fool Sterling. And a then reed switch
to let "generator" shaft run from utility power along with the other stuff.
What I would need for video proof of operation is:
What I would need to see on the Internet is the device suspended from
the ceiling on a relatively clear nylon rope(s) with two infrared bathroom light/heat bulbs
pointed downward onto a device on UPS that can detect a one second infrared light
drop out and turn on an indicator lamp (on utility power) if it detects that happening.
Next to it a clock that can read 24 hours time and date. A locked room etc. A piece
of cardboard before and after the run would be used to interrupt the infrared optical
beam and show that the detector works.
This would not be proof but as close to proof as possible on the internet.
It would help put the critics on notice that their jig is nearly up.
I need this as proof for every and any contending device. MagnaCoaster, Midtek, Yildez.............
Their device would not consider real unless they did this.
:S:MarkSCoffman
crazycut06
Look closely guys, this is fake, if he did not do the bulb test he had been credible, notice there are two holes at the board and ground where he aligns the machine for electrical connection hidden under, so why nail it to the ground? Because of vibration? I don't think so  :P  Then as he starts the machine, simultaneously closing the magnet motor suddenly the bulb went on, even if the generator isn't up to speed, likely there's a switch connected somewhere, and when he stops it, why he applied brake to the motor and quickly opened the motor? Rather than letting it gradually slow down to see if the lights dimmed down? Fake!  :P
T-1000
When looking on another video in
http://www.youtube.com/watch?v=yodY1jH5j-I
http://www.youtube.com/watch?v=lCMuDBajFjU
I could not see any hidden wires/etc in the yard there.
And also the magnetic motor is not utopia - as long as you bend basic physics laws for magnetic pull, push and creation of bloch wall in correct time. Then strong neodium magnets can power kilowatts of load without problem... ;)
The Gary effect might be involved there too - http://www.rexresearch.com/gary/gary1.htm https://www.youtube.com/watch?v=n3f8v9bjx7g and that goes to the very old days - Canadian Patent #10239 (July 16, 1879). http://www.youtube.com/watch?v=V4GAwD3c7jI
NTesla
Quote from: T-1000 on February 02, 2014, 08:39:03 PM
When looking on another video in http://www.dailymotion.com/video/x1asgtf_challange-to-the-engineers_tech I could not see any hidden wires/etc in the yard there.
He should detach the 'alternator' from the generator and let the generator operate on it's own. That would settle the most obvious source of fraud. Yet he doesn't...if I had an alleged 'free energy' device like this, this would be the first thing I would demonstrate.
crazycut06
I was reffering with this video, the wires are hidden underneath the soil where he nailed the motor to make a connection from mains.
