The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
0 Members and 17 Guests are viewing this topic.
MeggerMan
@brnbrade,
Quote from: brnbrade on July 07, 2007, 04:21:01 AM
We have the necessary information.
Now it is building RMF.  ;)
Please post a circuit diagram of your set-up so we WILL have the necessary information.
Rob
Doug56
@btentzer
I connected the device from headphone output as shown in bellow illustration.
@wattsup
QuoteLook at Trial #1 again more closely, you will see that they are wound the same.
Please, examine the pictures carefully. I highlited the winding and each set, and this seem in reversed orientation. I don't know if that makes some difference, but maybe only making tests to see.
@ Stefan
Thank you for informations. I will examine my experiments carefully henceforward. I will also try use a MP3 portable (like iPod) in my next experiments playing music and pure frequencies. I notice when I use low frequences, the voltage is also low, and when I use high frequence, the voltage increase, independent to amplitude.
In any way, only tomorrow I posts the new results, because I have to build some hardware to make the tests.
Doug
Bruce_TPU
@ Doug
Thank you for the recheck
I think you idea of amplitude affecting things is keen and correct!
@ All
I would certainly continue to experiment, but I believe from past experience that Rob (meggerman) might be correct.
On my very first TPU that I wound, It showed 38 volts AC with nothing connected.  It was NOT OU, everytime my hand approached the volts went up, even connecting the voltmeter to it caused it to happen.  It's close proximity to anything electrical and it just picked it up.  It had no current whatsoever.
Cheers,
Bruce
Bruce_TPU
@ Doug
A good experiment for you would be to seperate the right channel and input it on the opposite end of the coil, to give you same signals, opposing one another, slightly out of phase.  IF it is stereo.
Many thanks.
Bruce
Hi Doug,
many thanks for posting the new pictures.
What about using white noise as the audio source ?
Please try this also as this has many high frequency components.
ALso try to put a real load resistor onto your output parallel to your
DVM cables, like a 10 Ohm to 1  KOhm resistor and measure then again the voltage at it.
You can then also only use one channel of the stereo audio output,
as with stereo some frequency components from the noise could otherwise cancel out.
Many thanks in advance.
Regards, Stefan.
