The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
0 Members and 40 Guests are viewing this topic.
weri812
PUT YOUR MIND IN GEAR BEFORE  YOU PUT YOUR MOUTH IN MOTION
Hello wer,
enter "it",go to "Description" and then -on the right side "Translate ..."
Hope, this will help !
What a luck,for me (less work !)
S
dL
p.s.: but he,Adolf Zielinski,invented some more-"e-pump"-related
weri812
@ iancaIV
thanks that worked
wer
jacob
Quote from: brnbrade on July 08, 2007, 01:45:00 AM
@ Jacob
Sinto muito. Nada a declarar para voc?. Venha ver meu despositivo trabalhando.
? facil levantar um nome e apontar um dedo. Eu iria postar meu diagrama como prometido em duas ou tres semanas, mais n?o sabem esperar.
Copiar ideias ? f?cil. E fazer funcionar? Eu consegui...
? engra?ado. Todos que est?o tendo sucesso est?o sendo devorados vivos por alguns. Alguns que s? teorizam. bal bla bla
SM foi grandioso e astuto, mas n?o vejo sua tecnologia disponivel para n?s.
Brnbade,
You maintain that you do have something real. Well, I am ready to trust you on this. But you need to substantiate your claim. Either your lighted halogen bulb picture is genuine, in which case, please tell us more about it. Or your picture is not genuine, and you need to say so.
So here is the question plain and simple: The bulb picture that you've posted implies that you are getting a very high COP (10 or more) from your setup. Is this real or not?
It is obvious from your latest posts that you do understand english, and that you can write whole paragraphs in Portugese. So there is no communication barrier.
It's ok if you don't want to tell everyone about "the special ingredient" that makes you coil behave much differently than any other. I'll do it. But please clarify the situation. Tell us more about more about what you are observing when the bulb lights up. If you say nothing, it's only natural to assume that you are a fraud. Even your email is inacurate (unless you've corrected this problem, have you?). You must admit that it doesn't look too good...
Jacob
Can please all people, who have rebuild this thing please connect a load
resistor of about 100 Ohm to 1 KOhm and let us know the voltage at it ?
If you only use a digital Voltmeter or a scope with their high impedance input,
one can not know, if there is only voltage at the output or also current ?
Please let us know, the load resistor value and the voltage at it.
Good would be also a scope shot and note the deflection time in milliseconds/div
and the input voltage setting of the scope in volts/div.
Many thanks.
P.S: @Wattsup,
when your 2 transformer setup went again to over 8 Volts,
what happens, when you connect a 100 Ohm or 1 KOhm
resistor there ?
Is the voltage going down very fast ?
Is it AC or DC voltage ?
Can you get 2 transformers where you can post the full specs from
them and which could be bought at an available source like eBay or Radioshak
or something like this, so we can repeat this experiment ?
Pleaselet us know the exact types you will use then.
Many thanks.
Regards, Stefan.
