Crystal Cell Research
Started by plengo, October 29, 2012, 06:08:15 PM
halfvulcan
Note to self: can't delete posts.
halfvulcan
It takes some tinkering before you'll convince yourself these crystal cells are real. I haven't been the most scientific perhaps, but I can tell you I've proven it to myself. I just dont have it documented to show you the proof unfortunately. I wanted to add, I made some wire-based dry crystal cells some months ago and used red plastic drinking straws and superglue to seal them from outside moisture. Suddenly they lost ALL POWER within hours, maybe minutes. They wouldn't put out anything. I took the straws off and suddenly they worked again. Not just one. This was with about 4 cells. Same effect with all of them. I intend to try this again eventually because that blew my mind. I have no idea why that would happen unless there's something about the straws that was somehow blocking the energy the crystals need. And thanks for explaining about your coating method. That's amazing. I'll be trying that.
Okay, what JH is doing maybe isn't the same as a crystal cell, but thought it would be interesting to us. Notice he mentioned that he "coated the wire", "pickled" it. That is somewhat significant I bet, or else he wouldn't have bothered with it. https://www.youtube.com/watch?v=Td9OpWJz13w . This guy comes off a complete lunatic at times, but he seems to be legit.
More on subject, linking to one of IBPointless' videos if he doesn't mind. This is some data that Ibpointless was awesome to provide to prove what he already had proven to himself pretty thoroughly by this point. https://www.youtube.com/watch?v=BH5NGKpRw0E . But also, I recommend a look at all his crystal cell videos. It helped me.
mscoffman
Crystal cells are real. There is nothing wrong per se with galvanic reactions. Life needs water to ionize and dissolve solids, then those
ions and particles spread out in the water evening out their own densities so that other processes can pick them up. Water is
the great ionizer. Ions are used in a battery for charge mobility. The problem is it is difficult to stop the process and protect
the metal poles of the battery. I was wondering if there are any other fluids that ionize but might be easier to control than water.
Those hydrate cells where people add small amounts of water may be piezo pressure based. Lazersabre says his cells are slowly
ejecting their electrodes as the water gets converted to additional OH hydrate material. I think the initial copper oxide layer they
put on those copper bowls will protect them from water corrosion.
Crystal Cells work on something called Petrolithic energy. Rock crystal energy. Stars like the Sun cannot fuse Hydrogen to Hydrogen
directly so the they use a side reaction called the positron-electron-positron II pathway. This produces PEP-II neutrinos. Those
reaction equations in physics have to balance just like chemical equations do. PEP-II neutrinos carry away the angular momentum
from particle spin from the star reaction. Neutrinoes are like ghost particles they don't interact with matter hardly at all, Except
it's like tuning a radio, if a reaction needs just the right energy then bamo the reaction goes ahead with just the energy it needs.
It's like a radiant field, buts its not a real field, its these particles. Put 200 atmospheres of hydrogen into a metal tank to tune it
and bamo neutrons come out it. I suspect this is the driving force for LENR reactions generally.
:S:MarkSCoffman
jonfrommanahawkin1
I've come to the realization that how or why they work really doesn't matter but if we all work together to find cheap/free/renewable energy, does it really matter?
because at the "finish line" no one will really care how or why
And as I read these comments I bet there's more knowledge on just this post then any university combined
Please let's stop asking why and start passing the finish line
Jon
mscoffman
Yeah, I think this is a great thing. Imagine how many of the PM machines on overunity.com would work, if you could just add some
magic wire.  ;)
