Compress air engines
Started by TommeyLReed, June 07, 2014, 10:52:09 AM
TommeyLReed
I have many years in designing engines that run on air, this is just some of my designs:
http://search.aol.com/aol/imageDetails?s_it=imageDetails&q=tommey+reed+ratchet+piston+engine&v_t=comsearch&b=image%3Fv_t%3Dcomsearch%26q%3Dtommey%2Breed%2Bratchet%2Bpiston%2Bengine%26s_it%3Dtopsearchbox.search%26page%3D2%26oreq%3D146cd775bc584f1887662d540ba50db4%26oreq%3D608dceaf7ef443e285b42dee86e049a8&img=http%3A%2F%2Fwww.faqs.org%2Fpatents%2Fimg%2F20100139477_11.jpg&host=http%3A%2F%2Fwww.faqs.org%2Fpatents%2Fapp%2F20100139477&width=85&height=109&thumbUrl=http%3A%2F%2Ft1.gstatic.com%2Fimages%3Fq%3Dtbn%3AANd9GcTOZBrqODu76ubJcmG87qbrBrYKg-lvBihtB6XDEG6o0VwMHDf3ijpIkQ&imgWidth=128&imgHeight=165&imgSize=2056&imgTitle=tommey+reed+ratchet+piston+engine
One good thing about compress air is:
1) The energy you put in, is always store better then any battery.
2) Heat can increase pressure, as well as cold will decrease it also.
3) Low pressure air pumps can be used as wind pump turbine to store the wind in tank.
4) my submersible engine use 5psi at higher cfm to generate lots of hp in oceans or lakes. as the waves move up/down the floats generates low air pressure that is force  pressure 10ft under water to a displacement system. As this unit is force upward it creates mechanical work. Wind turbine can also be added to pump system.
ramset
Sir
Are you familiar with the work of Lee Rogers?
I am seeking info on his air engine...
do you have a shop for replication work [light machine work] ?
thx
Chet
Thanks Grandma
TommeyLReed
Hi Chet,
Look up Terry Miller air can in the 80's, interesting project also.
I have a small basic machine shop in my back yard.
40"x7" metal lathe
15" lathe/mill
7" metal lathe
Sherline cnc
welders
metal cutting
plasma cutter
20 ton press
drill presses
and other types of tools.
This does not count for the electronics equipment also.
I would say 50K+ in tools
Have a beer, I will rather buy a tool......
ramset
Yes  I completely agree the tools are much better than the beers.
sent you a PM
thx
Chet
Thanks Grandma
Qwert
Quote from: ramset on June 07, 2014, 02:30:48 PM
Sir
thx
Chet
Lee Rogers' patent:
http://www.google.com/patents/US4292804
