KARPEN PILE
Started by Philip Hardcastle, May 22, 2014, 10:41:32 PM
profitis
Did you try the gadgets anode with a graphite cathode pomodoro.what happened.
mscoffman
Congratulations profitus and pomodoro. I am very impressed with the accuracy
of both your exploits. One thing you should do is go for one completely sealed
cell with maximum "staying power".  It's hard for the general public to accept
that flowthrough method is not supplying hydrogen "fuel" to the reaction, plus
it is a waste of hydrogen gas.
On the you-tube videos of the real Karpens pile in Eastern Europe from pomodoro's
you-tube home page. I was negatively impressed by the poor quality of the seals on
the real Karpens cells. I was somewhat shocked that they don't appear to have used
frit glass seals on the original Karpens cell. I wondering if we could eventually
expect to see oxygen leakage and cell malfunction on the Karpens Piles because
of this? Also they had a picture of a depolarization mechanism that looked inactive.
I hope this is a filmarker's flaw of taking a picture of a disconnected device or
a secondary backup device. I could just see the cell voltage of Karpens Pile
be 1.00V but where the current has dropped to zero and is unable to activate it's
depolarization device any longer, And yet the curator is pulling it out and saying;
"Here it is gentlemen; Karpens Pile." There is another picture of those cells in
a box covered with Sulfuric acid corrosion. If they couldn't handle this correctly
then maybe they *should have* given it to the French.  I suspect that they may
not have valued these much at first, but then history set in.
What I'm saying is eventually your cells may be the only working Karpens cells in
existence, so proceed with care.
:S:MarkSCoffman
pomodoro
Yep that's the one that did not recover. I will need to look into it further.  Now I can't figure out how I'm getting 900mv. All the journals I've read have a much lower value . for example Google 13(2)_P77-101.PDF.
profitis
Aha my mistake.I thought silver vs secret meant silver with secret.ok no graphite lets go of H atoms very slowly.its not so easy to find exact numbers in lists pomodoro.you must remember we are working with galvanic overpotentials for batteries not electrolysis overpotentials.activation overpotential is the key,very dependant on material makeup,surface area,gas exchange rate etc.a number of factors.
profitis
Thanks marcscoffman.scientist viewers will accept it quickly but yes for the layman viewer a sealed system is best for conviction.karpens romanian device has air trapped in it so if there's a tiny hole in there it won't matter too much.sulfuric acid doesn't crystallize or dry out in open air either it stays in solution which is why I think he could say with confidance that that robust thing will last a lifetime and beyond.
