turbo
Yes Mannix, the saturation of the core is diffrent in one way then it is in the other,and this is due to the external magnetic influence of the field that is already present from the earth or in a tpu generated by the coils around.
this is the basic operating principle of a magnetometer.
you saturate in two directions and then you demodulate so the only resulting output is that external magnetic field.
As you might know you need 3 of them to measure the complete external field.
M.
PS. i believe theze "center torroids" are bifilar wond coils.
i have also experimented with these having 4 coils.
and offcourse last week with the transformers in the video.
needles to say the center torroids in the tpu could be air cored which does not saturate ,so then we have a diffrent situation.
BEP
Since this is the main thread:
Has anyone consider using a von der Pol oscillator for the third pulse (frequency?)?
It isn't useful if you want to stomp the neighbor's stereo but it might be needed to have a continuous effect.
Once the little critters are organized they probably won't stay that way unless they have the proper beat to make then stay organized.
This would follow many posted lab reports for generation of power by magnitudes and should meet the Sm description of 'variable tuning'.
I did a search and didn't see it.
If useful then it should probably be referenced off of the second frequency.
Motorcoach1
 I've had some time to work on my Tpu it's a modafied version of Ott's set up and now crossing back over to the SM type  windings.  If you notice in the photo the coaxl cable is inside the aluminum tube, this was quite diffacult to do with all the support plexi holding evrything in place.  now the pain stakeing part of winding the coils , 3 each on , the rings.  I will be testing with a cascade circut and then a duel transformer circut, and a sequential 5 to 10 hrz timer circut. what I'm looking for is takeing the secondaries and and sequence them in order and see the results of the test and speed it up useing 2 frequencies. I've read so much now i'll try it and see what the out come will be. It may not be over unity but I'm sure that i will be able to create a higher output on the finals. The small test I have done gave good results so i'll take the best of the winding and put them to work on this unit. Yes Dr Mark S. is correct neatness counts so i'm takeing my time in the winding of the primarys and secondaries.      hahahaha @BEP I need one of those Vander Pol occilators , might help in the rolling boom boxes going up and down the street ,  ;D   If there are any suggestion , -much apprciated . Mike
Bruce_TPU
It's looking great, Mike!
Keep us posted!
Warm regards,
Bruce
margiemirage
I have a feeling that this device is the real deal, call it healthy optimism.
What boggles me though is why a seemingly intelligent person like Mark, knowing about the billion dollar oil interests and how they can cover-up competition since they "have the world governments in their pockets", sells the invention to some lawyer instead of giving the technology to the masses before it was buried by the greedy oil bastards. Ten years ago, the internet wasn't what it is today. But NOW he could do it. Why not share it with as many people as possible. There's power in numbers. It's bad enough that the Federal Reserve is a privately owned bank with no reserves and that the big bankers have been stealing our money through the biggest fraud ever perpetrated on a nation called Income Tax, which btw is unconstitutional. But now we can't even have this? Just lowers his cred me thinks, especially when he brings God and mission into the picture. But hey, I don't have anything to lose by hoping. Good luck Steven and God Speed to ya.
-Margie
