hanon
Quote from: forest on August 16, 2014, 02:54:33 PM
hanon
Can you post link to www page where you posted all Figuera and Buforn patents with translations ?
I think it is now quite clear how they worked, in theory.  ;)
Website site with all the documents:
http://www.alpoma.net/tecob/?page_id=8258
madddann
Quote from: antijon on August 15, 2014, 10:13:52 PM
Hey Cadman. I don't think that modification would be necessary, and here's why. If you look at the photo that Marathonman posted, you see the fields "breaking out" at the center of the output coil. Now if the action that produces output is based on that "breaking out" point sweeping through the coil, then the amp-turns aren't as critical.
My initial thoughts about the Figuera generator was some special phase/transformer action, something that produced some special output. But like you said, under normal conditions and effects, it won't produce good output. So I've been trying to wrap my head around the actual action, the method that produces the effect. If you watched Gotoluc's videos, you'll see what it is. Like Marathonman's photo, it's the sweeping field that produces current.
To simplify the action, you need two like poles "breaking-out" at the center of the output coil. Then you move it back and forth. I've attached the circuit that I tried last night on my dual-primary transformer. The two primaries are arranged with like-poles facing each other. The purpose of the resistor is to provide a constant current to both coils. As the center-tapped transformer goes through 180 degrees, it produces the sweeping effect. As it is shown, this did produce more output than if the two primaries were simply wired in series and fed AC from the transformer..
In my opinion, the action is incredibly simple. It can be produced in many ways. Say, with two permanent magnets, like poles facing, and two primaries being fed AC. Or with two DC coils and two AC coils.
Hello and welcome antijon!
Could you please tell where in your circuit is the input (AC mains) and where the N and S electromagnets are connected?
A full schematic would be awesome (just draw by hand, take a picture and upload).
Also, do you happen to have one of those energy meters to check out the consumption?
What is the resistance and power rating of the resistor?
I do experiments from time to time and would like to replicate this setup to see for myself what's going on and report any good results.
Thanks in advance.
Dann
RMatt
Is there a cure for the post and pic's that are oversized???? I hope that I am not the only one that has to scroll right then left then down then right....... to read every post. It is quite annoying. Does anyone else have the same problem?
gyulasun
Quote from: RMatt on August 16, 2014, 05:36:27 PM
Is there a cure for the post and pic's that are oversized? ??? I hope that I am not the only one that has to scroll right then left then down then right....... to read every post. It is quite annoying. Does anyone else have the same problem?
Yes.
the solution is: If everybody were to upload pictures with max 800x600 pixel sizes (and not 1200x or higher) then the page would not be oversized horizontally and we would not have to scroll to the right.
Stefan Hartmann has already written this somewhere...
The remedy for an oversized picture would be to resize it for a lower pixel number by the uploader, within 12 hours after he or she posted it.  This would involve deleting it from the forum  (uncheck attachment) and after resizing it could be uploaded again.  After 12 hours the Modify button disappears and you cannot edit your posts, only the Moderator can.
Gyula
madddann
Hi!
If you are a firefox user check out "Image zoom" add on. It lets you resize any image displayed just by holding down the right mouse button and turning the mouse wheel. So If the text is out of screen, you have to check the page for large images, right click and scroll on them and then you can read the page.
Here: https://addons.mozilla.org/sl/firefox/addon/image-zoom/
Not exactly a fix, but more like a remedy. Hope it helps
Dann
