marathonman
Yes i know i am guilty as charged and i will make sure from now on the pics are smaller. i just forget that my Monitor is 46 inch not 19 or 20. i don't ever run into these problems with a large screen. i use to have a 60 inch monitor but that's in the living room now.
So will the pic of the double pinch effect work or not i am curious to try though but i don't have enough core material yet.
marathonman
Hannon,
I thought Figueras devise put out 550 volts.? if you say less than 10 volts per coil then that is one hell of a loss coming from 100 volt @ 1 amp stimulating. to me this does not seem correct at all. at 550 % 7 coils is 78.5 volts. where do you get your figures. please explain!
stupify12
Yeah. 8) We got it guys. ;D It is as said by Senior Figuera, current can be produce by varying the intensity of the Exciter Electromagnets with the very well known principle of Increase and Decrease. The Exciter Electromagnets is the most crucial design so that this varying intensity of magnetism will be induced perfectly to the Induced Coils/Generating Coils.
It was clearly cited by Senior Figuera on all of his patents, one must think deeply to really understand those simple words/translation to fully understand this very simple concept which derive from Faraday.
The perfect design for the Exciter Electromagnets ;
1. Two Perpetual Motion Holder(PMH) facing each end-by using this kind of core the 1st Electromagnet is bend so end  of the U shape core will project South and North.
2. The Homopolar Design of Nikola Tesla with very clear winding direction and magnetic poles of the Exciter Electromagnets being of opposite pole while a disk is rotating inside.
3. The Patent 30378 is another best design for the Exciter Electromagnets of this Figuera Generator.
The rotating resistor is the swiping component that well make this Two Exciter Electromagnets vary in intensity. The 1st Electromagnet is being increase, at the same time the other Electromagnet is being decrease; vice versa. The Elementary drawn Resistor of Senior Figuera is being swipe from Left to Right and Right to Left. The input source on the Elementary Resistor is the Positive Terminal connected in each level of Resistance.
So we could say that when the Pin(Wiper) in the Middle of this Elementary Resistor  the Two Electromagnets are being power with the same intensity of Positive Terminal. When the Wiper is on the Left of this Resistor the less Resistance(e.g. the N Electromagnet= North + South) is on the maximum magnetic field while at the same time the more Resistance (the S Electromagnet=South + North)  Electromagnets is on the minimum magnetic field.
It is so simple as per Senior Figuera stated he just improvised how a rotating dynamo principle work into a Motionless device. We need a Two Electromagnet with two North and two South, if you could bend the core is much better.
Meow
Quote from: antijon on August 15, 2014, 10:13:52 PM
Hey Cadman. I don't think that modification would be necessary, and here's why. If you look at the photo that Marathonman posted, you see the fields "breaking out" at the center of the output coil. Now if the action that produces output is based on that "breaking out" point sweeping through the coil, then the amp-turns aren't as critical.
My initial thoughts about the Figuera generator was some special phase/transformer action, something that produced some special output. But like you said, under normal conditions and effects, it won't produce good output. So I've been trying to wrap my head around the actual action, the method that produces the effect. If you watched Gotoluc's videos, you'll see what it is. Like Marathonman's photo, it's the sweeping field that produces current.
To simplify the action, you need two like poles "breaking-out" at the center of the output coil. Then you move it back and forth. I've attached the circuit that I tried last night on my dual-primary transformer. The two primaries are arranged with like-poles facing each other. The purpose of the resistor is to provide a constant current to both coils. As the center-tapped transformer goes through 180 degrees, it produces the sweeping effect. As it is shown, this did produce more output than if the two primaries were simply wired in series and fed AC from the transformer..
In my opinion, the action is incredibly simple. It can be produced in many ways. Say, with two permanent magnets, like poles facing, and two primaries being fed AC. Or with two DC coils and two AC coils.
stupify12
All is the same with the Law of Induction. Put many coils on the Induced Coils connect them on parallel for more amperage output. Connect this coils in series for more Voltage output. As long as this Induced Coils are being cut with the lines of force of the Magnets/Electromagnets.
This coils can be cut with the lines of flux of Magnets rotating the Magnets or the Induced Coils.
Figuera's principle is of being born and dying Magnetic Lines= which is equal to Varying the intensity of the Exciter Electromagnets by feeding it with Increasing and Decreasing Magnetic Field.Sounds the same with the principle Approaching magnetic field and moving away Magnetic field.
One must understand how a DC Dynamo works to produce current, which is also describe by Senior Figuera on most of his patent. The same principle with this Figuera Generator it works on the DC Dynamo principle, a Coil wound in a bar of laminated iron, when the Magnet is passing with a magnetic pole of North on top and South in the bottom it moves away, and the Magnetic pole now approace the Coil with a magnetic pole of South on top and North in the bottom.
The same goes for the Figuera Generator instead of rotating the Magnets, the Wound Coil is being hit with the Magnetic lines of reversing Magnetic field; let say the 1st Electromagnet project North on top, and South in the bottom with Maximum magnetic strength, while the 2nd Electromagnet project not much on this cycle because it is on the Minimum Magnetic strength.
When the wiper moves to the Maximum Magnetic strength of 2nd Electromagnet which project South on top and North in the bottom. The Induced Coils now are already cut with the magnetic lines of Reversing field because the Induced Coils is stationary. The 1st Electromagnet project not much on this cycle because it in on the Minimum Magnetic strength..
Meow    :D :D
Quote from: marathonman on August 18, 2014, 10:55:13 AM
Hannon,
hanon
Hannon,
Figuera obtained 550 volts and 15 HP as you said in his 1902 generator, as reported in the press from that year. The reference to 20 KW output ( 300 A  @ around 60 volts) is from the Buforn patent from 1910 which was a copy of Figuera 1908 patent. We dont have to mess it up between both different patents  from Figuera: he filed 4 patents in 1902, and he filed his last patent, the one with the commutator, in 1908. I think that concepts used in 1902 patents and sold to bankers are not the same than those issued in 1908
