Kapanadze Cousin - DALLY FREE ENERGY
Started by 27Bubba, September 18, 2012, 02:17:22 PM
0 Members and 1845 Guests are viewing this topic.
itsu
Quote from: Void on October 20, 2014, 08:28:15 AM
Hi Itsu. It has not really been translated what Ruslan said when he drew that connection between
the two yoke secondary windings. It would help if a Russian speaker could translate what he said there.
I wasn't clear at all if Ruslan was just showing that you can ground one side of both windings, or if he was
saying that a possible variation is you could do away with the series resonance winding and 2x25 winding
part and just drive the grenade winding directly with one secondary winding on the yoke. Maybe he was
just pointing out that you can ground one side of both windings however. Not sure at all.
The following might work. If your function generator has a setting that produces a good broad frequency white noise signal
well into the high MHz range, you could drive your grenade coil with that and monitor with the FFT spectrum analyzer mode
on your scope. You should see some peaks at frequencies where there are resonances. Although
Akula made a video talking about locating such resonances, Ruslan seems to put little importance
to them. Ruslan says he is basing everything thing off fractions or multiples of wire length.
Seems to be working for Ruslan. :)
All the best...
Thanks Void,
i could try that last part, seems doable.
Regards Itsu
T-1000
Quote from: itsu on October 20, 2014, 07:54:30 AM
Hmmm, my grenade does not have any parallel capacitor and it does not resonate in the low KHz range, more like
970KHz, 2.1MHz and 4MHz (self resonance).
What is total length of wire in grenade coil? You need to treat is as receievr antenna,same wavelength calculations apply there. Also multiply that by 4 and divide by 3 then you will know Tesla coil + antenna aimed wavelength and multiply by 100 for induction heater target wavelength. Then you can convert that into frequencies for resonances.
Quote from: itsu on October 20, 2014, 07:54:30 AM[/size]Concerning your request about "to record in high resolution complete cpectra", no problem to help if possible, but i am not sure i follow you.
My Tektroniks oscilloscope is just that, an oscilloscope, no spectrum analyser, or do you mean the FFT function?
I then need to sweep the whole range  0 Hz up to 100 MHZ  using my Function generator.
And what to scan?  The grenade coil, the 2x 25turn bifilar coil?  Please explain.
Regards Itsu
No need to sweep frequencies in grenade coil, there is nothing related to LC resonance. This is what Ruslan stated clearly in Teamspeak conference...
T-1000
stupify12
Let me add some no important information. This is already very clear that this is the work of Nikola Tesla
The Bifilar Grenade coil only work as a Receiver of RADIATION. That is why we call it Radiant Energy comes from the word RADIANT SUN. Imagine you are holding the power of Sun Rays on your hand?
The Bifilar Grenade Coil is the Insulated shiny metal conductor= Elevated Capacity.
The Kacher Circuit is the Resonant Tesla Coil that work as Transmitter here of Rays/Radiation.
The Bifilar Grenade Coil which will work best if LOOP like an antenna, is connected on the first armature/terminal of the 1uf/2000v Capacitor(1-10uf)= The Bifilar Grenade Charged Recieving Coil is being charged with Positive charge particle as per Tesla's words. To complete the energy on the HV Capacitor we needed a zero difference potential source which is the GROUND/EARTH.
The second armature/terminal of the 1uf/2000v is connected to the GROUND/EARTH, Tesla usually connect the second armature/terminal of the considerable electrostatic capacity Condenser on the GROUND/EARTH.
Just some speculation. Take it or Leave it.    ;D ;D ;D ;D LOL
Always remember Rays/Radiation, this is the only way for a device to work in Free Energy or Over-Unity.    MEOW ;D ;D
Meow
Tesla
QuoteThe insulated plate or conducting-body should present as large a surface as practicable to the rays or streams of matter, I having ascertained that the amount of energy conveyed to it per unit of time is under otherwise identical conditions proportionate to the area exposed, or nearly so
QuoteThe second terminal or armature of the condenser may be connected to one of the poles of a battery or other source of electricity or to any conducting body or object whatever of such properties or so conditioned that by its means electricity of the required sign will be supplied to the terminal. A simple way of supplying positive or negative electricity to the terminal is to connect the same either to an insulated conductor supported at some height in the atmosphere or to a grounded conductor, the former, as is well known, furnishing positive and the latter negative electricity
QuoteAs the rays or supposed streams of matter generally convey a positive charge to the first condenser-terminal, which is connected to the plate or conductor above mentioned, I usually connect the second terminal of the condenser to the ground, this being the most convenient way of obtaining negative electricity, dispensing with the necessity of providing an artificial source. In order to utilize for any useful purpose the energy accumulated in the condenser, I furthermore connect to the terminals of the same a circuit including an instrument or apparatus which it is desired to operate and another instrument or device for alternately closing and opening the circuit. This latter may be any form of circuit-controller, with fixed or movable parts or electrodes, which may be actuated either by the stored energy or by independent means.
QuoteThe sun, as well as other sources of radiant energy, throws off minute particles of matter positively electrified, which, impinging upon the plate P, communicate continuously an electrical charge to the same. The opposite terminal of the condenser being connected to the ground, which may be considered as a vast reservoir of negative electricity, a feeble current flows continuously into the condenser, and inasmuch as these supposed particles are of an inconceivably small radius or curvature, and consequently charged to a relatively very high potential, this charging of the condenser may continue, as I have actually observed, almost indefinitely, even to the point of rupturing the dielectric.
MEOW ;D ;D
d3x0r
Quote from: Void on October 20, 2014, 07:02:22 AM
Hi d3x0r.  Driving a tesla coil with the primary windings at the bottom or at the center will definitely
give some difference in results. It depends what you are trying to achieve.
The 2N3055 has a max frequency spec (Ft) of 2.5 MHz. The 2SC5200 has a max
frequency spec of 30 MHz. The 2SC5200  should give a much better performance in a kacher circuit
running in the low MHz range.
All the best...
what I was using before; but don't have timing specs... was resonant about to 1.2Mhz
http://www.nteinc.com/specs/300to399/pdf/nte327.pdf
http://www.nteinc.com/specs/2300to2399/pdf/nte2319.pdf
2sc5200 (almost) equivalent...
http://www.nteinc.com/specs/2300to2399/pdf/nte2328.pdf
going to try to get some of those; because I have good high frequency ringback now... but I suspect it's from the primary only...
