0 Members and 71 Guests are viewing this topic.
Cadman
You may find this interesting.
Dr. Silvanus P. Thompson who was the president of the Institution of Electrical Engineers as well as a professor of physics at the London Technical College, wrote in one of his series of books on Dynamo Electrical Machinery that he and an associate were investigating this same type of set up, a stationary field and armature with rotating iron in between. He wrote that the preliminary results were very encouraging.
That was written sometime between 1893 and 1905.
Cadman
I hate to sound like a know-it-all but I'm sure I know exactly how this works and why it takes so little effort to rotate it.
The generator he is using has a 4 pole/coil rotor already and the poles with coils bolt onto the shaft. Unbolt the coils and poles, machine the shaft to get a 1/2" or so of clearance for the new iron pole shoes and reattach the 4 poles.
The 4 new rotating iron pieces are like detached pole shoes. As they rotate, the inner and outer surface, in fact the whole shoe, takes on the polarity and strength of the coils beneath them, and greatly reduce the reluctance at the same time. They also rotate the field lines providing flux cutting just like the original armature.
Also as each shoe transitions between a N pole coil and a S pole coil, or S to N, there is a magnetic attraction from the next pole to the shoe that aids rotation. It's a built in motor, and this is probably the major factor in reduced input HP.
I gotta get me one of these :)
lumen
I think before we determine the workings of the generator we should wait for syairchairun to get permission to release the actual construction of the 100 RPM generator shown in the videos.
There are many theories how this works but unless you know the exact construction you will be playing the same wild goose hunt as always.
If syairchairun can get permission to release the exact 100 RPM generator design, then replication and verification would be simplified.
It's my opinion that the 4 pole design will suffer much of the same problems as a conventional generator. Pushing iron that is essentially a magnet across the windings will have the same drag effect as a magnet.
