Gyroscopic Inertia Generator
Started by Scorch, October 18, 2014, 04:23:56 PM
If it's so simple and easy to replicate then go ahead and replicate it Synchro1.  Of course this is all fantasy talk from you, and we have seen it in the past.  Prove us wrong and replicate it showing your schematic, the full measurements, and the complete timing diagram.
Whether you really believe and act the way you do for real, or this is all a big put-on and you get some kind of psychological gratification and thrills from acting the way you do, either way it indicates that you have some psychological problems.  You keep on acting the fool and contributing no value whatsoever to this forum, then you will have to worry about administrative sanctioning coming down hard on you.
There you go again Synchro with your "patented" misrepresentation of the work of others and your straw-man arguments and misunderstandings of what is happening. Nice job Synchro, at least you are being consistent.
http://www.youtube.com/watch?v=mi_FJwpPrQk
In this video you can see the little core biasing magnets attached to the outer ends of the cores if you look carefully.
I can't at present seem to find my video explicitly demonstrating the effect of the biasing magnets on the cores but they do have a dramatic effect, and this is caused by the pre-saturating of the cores by the external field of the bias magnets, so that the cores are now pushed to different regions of their B-H hysteresis curves by the applied current pulses in the wires. This can indeed make the motor more efficient in terms of rotor torque vs. applied current, and the mechanism by which this is so is well understood. At least by some of us.
Low-Q
Quote from: synchro1 on November 17, 2014, 06:16:06 PM
Doug Konzen's magnet backed ferrite core generator coil would test positively as an overunity coil if he wired a capacitor in series with a fast switching diode between the coil leads instead of dead shorting them. Not only would the coil speed the rotor up and lower input in the sweet range of one half inch, it would generate and store additional current from the interaction of the backing magnets with the output coil windings. The generator coil backing magnets produce a separate and very powerful oscillating field that crosses the output coil windings. This extra field oscillation couples additively with rotor induction. Looping the stored magnet core generator capacitor output back to source by simply attaching wires directly from the capacitor leads to the power source electrodes would result in a COP>1. It's incomprehensible how wicked people like Milehigh can be allowed to act as vituperative as he has shown with no administrative sanctioning to cover a truth so simple and easy to replicate.
No. You're wrong. There is loss in every component you put into a circuit. The more you get, the more loss there will be.
Makes sense, doesn't it?
Vidar
synchro1
Quote from: TinselKoala on November 18, 2014, 02:15:39 PM
As usual it's practically impossible to identify anything in your video apart from the extensive rubbish pile that clutters your rat's nested habitation. The magnets Doug uses have to be many thousands of times stronger then those tiny neo disks you appear to use, as mine are, and retard the coil's pole formation to phase shift past TDC causing "Lenz Propulsion". My version uses diametric tube cores and a diametric spinner. You demonstrate no evidence of rotor speed up in your Orbette video.
Scorch
11/18/14
Hey MileHigh.  :)
Is it possible that John Bedini does in fact try to teach us and he actually does 'let on' for those with open minds, eyes to see, and ears to hear?
Is it possible that educational materials such as the "energy from the vacuum" video series and the three new reference books (and video) from JB actually do contain very useful information well worth the cost of a few reference books or DVDs?
Is it possible that those who negatively dismiss such reference materials as being "to expensive" or "they are just selling books" or "these systems will never work" may not EVER 'get it'?
The fact is-
If one doesn't bother to actually obtain and study the reference material and/or conduct a peer review experiment then; one has absolutely ZERO authority regarding said reference material he didn't read or study or experiment he didn't replicate.
Case in point-
www.youtube.com/watch?v=OEtiNum9MpM
Quote from: MileHigh on November 15, 2014, 02:54:16 PM
Scorch:
No I am not making the same claims about John Bedini.  I suspect he knows his stuff but he doesn't let on.
