T-1000
Mhm, seeing here much trolling and writing but no real attempts are not leading to any positive results...
Why people people can't make simplest experiment with cost under $50 to learn something new is also a good question.
The starting point - http://youtu.be/vtsHmE7_HDQ?t=55s
The explanation of what is happening - http://www.rexresearch.com/gary/gary1.htm
The resulting bench test  - the stationary magnet in middle, the spinning pieces of iron on rotor with air gaps very close to the magnet (less or equal to 1mm) and the variable distance between coil and rotor for finding and experiencing Gary Magnetic effect then observing how it impacts Lenz force and cogging when generator coil is shorted..
That cost mostly only your time and is cheap in money wise to learn something what was missed out completely in mainstream science about magnetism since 1867...
ARMCORTEX
What if effect does not manifest through smaller mass device.
Following the logic of it all, and the fact that I saw a similar video, with a guy turning a massive gen with his hand and lighting a room full of lights (unrelated video)
I have good feeling about truthfullness of general concept.
A used ST china type motor is not expensive if a used one can be obtained, and they are standard size under many companies.
I come to this site once in a while to see if something new and exciting has shown up, for many years I watch for such high quality potential project to appear.
I rate this technology 10/10 in all departments if true.
ketone
Working on it.... :) . Im still needing to cut the iron rings into corresponding pole sizes....i was thinking on adding 4 more poles though to make it a total of 8 poles (any thoughts?). A little more turning yet on the lathe to get more clearance ...stay tuned! 8)
P.S. Thanks Chet,sorry...iphone size ...so lifelike
ramset
Hello
Ketone
can you re-size that beautiful pic a little _smaller_ Please,we have to run back and forth to read/see it.
thx
Chet
ps
Thank you
Thanks Grandma
lumen
Ketone,
Nice, good to see another build under way.
Using a car alternator is a good inexpensive test setup but it is three phase and you might want to take this into account.
Possibly using 6 magnets and pole pieces instead of the four might match the windings better.
Since you asked  :)
