0 Members and 17 Guests are viewing this topic.
Just..Sayin..
Dog-One
Quote from: Just..Sayin.. on December 03, 2014, 07:08:05 PM
Thanks very much for the find.... Dog One
The trick is to view the page source, then cut-n-paste into google translate.
I can't say I'm encouraged about what that article tells us though, very likely Ramadan is a prisoner.  I wouldn't hold my breath on getting any more information than we already have.  I'm very thankful for what Syair has showed us; he certainly put himself in danger doing what he thought was right.
T-1000
Quote from: Just..Sayin.. on December 03, 2014, 01:45:00 PM
so I created a new generator that has a specially design , which can drain the efect lenz law to a different angle , fixed rotor induction of entry and large sngat and induction occurs when burdened can be streamed to the other , a simple example In the generator market : you 're running from the point A to C and in the middle there is a point B when you approach the corner b ye winds buffeted the opposite and when you pass you Mlah drawn , you definitely hard right to mencpai to the dot C , but on my generator that does not happen because there are no barriers negtif style was diverted towards the other is not destroyed krna energy lenz law remains.
Exactly, discharge magnetic field of magnet when magnet is UNDER coil and the Lenz force will be redirected. This is why you have to include iron bar between magnet and coil and discharge the magnetic field from one magnet into other with opposite magnetic polarity when iron bar is under coil... ;)
Also my CAD drawing is designed exactly to do that and also balance magnetic forces so the same generator coil can become motor driving coil..
Reposting here (remove .txt from FreeCAD drawing file Magnetic flux switching generator.FCStd.txt):
thngr
to T-1000
your iron bar need to be isolated slicone steel stack in-line with magnetic field or ferrite bar do you aware that?
T-1000
Quote from: thngr on December 04, 2014, 05:54:04 AM
to T-1000
The preference is same as the core in transformer which mean isolated plates to avoid losses.
The magnets here virtually replace primary inductor coil of transformer.
