ltseung888
Experiment to be done.
Is any one in a position to do the experiment?
Pull the weight in case c at the right time.  Does the seesaw action happen?
Morality Point:
We need oscillation, vibration, unbalanced rotation to lead out gravitation energy.  Can we add flux change when dealing with electromagnets?
ltseung888
Another experiment to consider.
The pendulum can be a spring.
Pulsing...
norman6538
reply to msg 2537 tests.
"A permanent magnet attraction to metal force is less than
the holding back force "after it passes the metal. If that were not
true then a pendulum would speed up when it passed. So there
is no gain but if you view this very sick pendulum you will observe
something against the known rules.
http://www.youtube.com/watch?v=4FzK2XKQ-74   30 seconds
Asside from the fact that it goes higher than its dropped point.
HINT: Watch the speed of the pendulum when it goes clockwise and then
compare that with its speed as it comes back.
Norman
Paul-R
Quote from: norman6538 on January 26, 2015, 07:39:48 AM
Aside from the fact that it goes higher than its dropped point.
The push from the magnets is counteracted by the opposite effect on the way back.
You need to consider a complete cycle, not aq part of one.
ltseung888
Some interesting videos related to our coming experiments
https://www.youtube.com/watch?v=iHhZZ9DuzK4
The big unbalanced wheel and the statement from Chalkalis that he wants to give this to the World.
https://www.youtube.com/watch?v=61-C0x6xtL4
Modified FM Chalkalis Energy Multiplier - 1330% Efficiency
The input motor is from a drill driving the big arm (unbalanced wheel) via friction.  The setup will increase torque.
Does the Unbalanced Wheel bring-in gravitational energy?  More experiments needed.
Morality point:
Add a flysheel to store energy.  Add an unbalanced wheel to bring-in gravitational energy.
