MAKE A MONOPOLE HOLLOW DOUGHNUT / CRYSTALS
Started by guest1289, July 06, 2015, 12:39:08 PM
guest1289
   A MONOPOLE MAGNETIC HOLLOW DOUGHNUT
     -  Make a  'neodymium hollow length of straight-pipe',  and then join the two ends of the  'neodymium hollow length of pipe'  by using a   'metallic curved length of hollow pipe' ( made of a type metal which is the MOST effective at being induced into becoming a temporary-magnet by the  neodymium-magnet ).
     -    Yes,  the actual shape of this  doughnut  would be a funny looking imperfect elipse ( oval ).
     -    Would this effectively be  close  to a  'permanent-magnet-monople'.
     -    THE POINT OF BUILDING THIS COULD BE :    THOSE PEOPLE WHO BELIEVE THAT THERE IS A CONSTANT MAGNETIC CURRENT FLOWING IN PERMANENT-MAGNETS ( WHICH COULD BE USED TO 'DIRECTLY'   GENERATE ELECTRICITY  ) ,     THEN THEY COULD TRY AND DETECT AN ELECTRICAL CURRENT ( converted to an electrical current from the infinite-magnet-flow )  IN THIS   'INFINITE LOOP'  /  'HOLLOW DOUGHNUT' /  circular magnetic tube.
    CRYSTALS AND MAGNETS
    Referring to crystals  piezoelectric effect,  and also to the magnetic-properties of some crystals,  could using a magnet on a crystal,   'some-how'  generate an electrical-current,   even using the  'A MONOPOLE MAGNETIC HOLLOW DOUGHNUT'  which I have described above.
     MAGNETIC-VORTEX OF PERMANENT-MAGNETS
      -  Some people claim that a   magnetic-vortex  exists  at the north or south end of permanent-magnets,   but I DON'T THINK ANYONE HAS MANAGED TO PROVE IT PROPERLY.
      -  However,  it would be logical to think that such a vortex ( a non-static, non-stationary ) magnetic-vortex  could induce an electrical current  in  something.
            -  I THINK THAT THE REAL PROBLEM WHY THEY CAN'T DETECT IT IS BECAUSE IT MUST BE AT SUCH AN UNUSUAL FREQUENCY ( like the natural frequency of the magnet ) THAT THEY DON'T HAVE THE EQUIPMENT TO DETECT IT (  NOTE :   I DON'T HAVE ANY EDUCATIONAL-BACKGROUND RELATING TO THIS PARTICULAR  STATEMENT  ).
            -  ALSO,  MAYBE TO  DETECT  THE  'VERY MINUTE ELECTRIC-CURRENT'  THAT COULD BE GENERATED BY THE  'MAGNETIC-VORTEX OF PERMANENT-MAGNETS' (  or even generated by a permanent-magnet  with no magnetic-vortex,  or,  generated by the  'MONOPOLE MAGNETIC HOLLOW DOUGHNUT'  described above ),   MAYBE SOMETHING LIKE   'GRAPHENE'  COULD BE USED ( since it's very fine and apparently the most conductive material known ).
ATOM1
interesting observation ! To me its all harmonics and string north is major scale and south is minor scale so simple ! You only flatten the 3rd note of the major scale to produce a minor scale .. I called it Dynamic harmonic response ! Not sure about your monopole ? And not sure about a vortex around a magnet you need to detach the field from the magnet to make it vortex ect ... The magnet is holding down the field so it can t move hahah !
ATOM1
guest1289
Quote from: ATOM1 on July 06, 2015, 04:08:27 PM
ATOM1
   ( I don't actually know what scales are,  etc,  even after reading about scales  )
   The only interpretation that my simpler mind could make of  your   'Dynamic harmonic response' concept,    is that the  'North Pole'  has a lower frequency  than  the  'South Pole' ,  OR,  visa versa  (  so I just replaced scales with  'simple frequency',   and I doubt thats what you mean   )
(   Interesting concept,  if I understand it in terms of frequency.    I also tried to fit your theory,   into the principle that 'direction of electron rotation'  in atoms determines a negative or positive magnetic field,  but that was too difficult.
    Some people even claim that 'direction of electron rotation' also determines gravity,  in other words,  reversing the 'direction of electron rotation' can result in  ant-gravity,  but that makes no sense,   since only magnetic materials have uniform  'directions of electron rotation' .  )
    Your theory( 'Dynamic harmonic response' )  made me wonder( about this  'Monopole Doughnut' ),     if you get a  large-neodymium-magnet in the shape of a pipe( solid or hollow ),    and then join the   'North Pole'  to  the  'South Pole'  by using a    symmetrically-curved-piece-of-pipe( made of the best metal that is turned into a temporary-magnet by the  neodymium  ),       then you would be feeding the  'major-scale'  into the  'minor-scale'  ,    I wonder what the result would be,   a  'middle-scale',  lol.
    I only posted this  'Monopole Idea'   since some people have posted  monopole-generators ,  and some people have theories that a magnetic-current flows like water in a pipe,  but they cannot test their theories since it's impossible to build a Permanent-Magnet-Monopole,     I thought this  'Monopole Doughnut'  design might be usefull for their tests
sm0ky2
interesting hmm....
I assume you mean a circular magnetic tube/ring/(toroid?), magnetized diametrically
such that one pole is completely enclosed by the other pole....
said magnet would also be asymmetrical, one field being larger than the other.... and probably the larger/outer one would be more dispursed
since they should be of equal total magnetic strength.
im not sure how that would help perpetuate anything,... if that were the case, we would already be perpetuating point charges...
but im sure someone would find something creative to do with such a "monopolar" magnet. especially if you have several of them, of various north or south orientation.
guest1289
Quote from: sm0ky2 on July 06, 2015, 07:47:51 PM
interesting hmm....
   My first post in this topic,  best describes what I am trying to achieve.
     I'm trying to achieve a   'circular magnetic tube/ring/toroid'(  by the method decribed in my first post  ).
      Ideally I would eliminate the specific-points  on the  neodymium-magnet  where the  'North'  and  'South'  poles are,    and therefore the   'circular magnetic tube/ring/toroid'   would just be left with  either a  clockwise  or  ant-clockwise  magnetic-field  circulating right around the magnet.
      However,  my method of building such a magnet ( described in my first post ) is to simply use a normal straight   neodymium-magnet,   and join it's two ends to each other with  a curved-piece-of -metal ( made of a type metal which is the MOST effective at being induced into becoming a temporary-magnet by the  neodymium-magnet ).     BUT OF COURSE THIS SHOULD BE BUILT AS SYMMETRICALLY AS POSSIBLE,  to achieve eliminating  the  'North'  and  'South'  poles .
     Because my method involves a  neodymium-magnet,  and relies on a  metal-piece   being induced into becoming a temporary-magnet by the  neodymium-magnet,   I am not sure that this would  effectively  eliminate the  specific-points  on the  neodymium-magnet  where the  'North'  and  'South'  poles are.
     Thankfully I cannot build anything ,  so it won't be a problem for me
