'Impossible' rocket drive works and could get to Moon in four hours
Started by Pirate88179, July 29, 2015, 01:12:10 AM
Pirate88179
Quote from: gravityblock on August 14, 2015, 10:47:45 PM
Another inversion of the truth!  Thanks for showing us what you thought you knew, but in reality didn't know.  High resolution maps of Earth's surprisingly inconsistent gravity field. (video)
Gravock
Well, there are anomalies attributed to the varying density of the earth at any given point.  Gravity is a function of mass and, in various places on the earth that does indeed vary.  But, gravity, a constant, does not vary.  It is the mass that creates the gravity in the first place that is changing....although very, very little.  If it really made a difference, a satellite would change its orbit depending upon what area of the earth it was overflying at the time.  I do not believe this happens in a manner that makes any appreciable difference in the satellite's orbit.
Bill
"George P. Dvorsky is a Canadian bioethicist, transhumanist, and futurist. He is a contributing editor at io9 and producer of the Sentient Developments blog and podcast."  So, this is the fellow that made the post where you copied that map?  OK, I can clearly see where we need to through out everything known in science and believe this guy......what credentials!
Look at the sources you are using here.  I mean...really?
gravityblock
Quote from: Pirate88179 on August 14, 2015, 11:00:24 PM
Bill
As we can clearly see in the map and video, the density, temperature, pressure, and magnetism has an effect on the gravitational force.  This and the Travis effect are both in-line with gravity being a combination of phenomenon and not an individualized force.  The attraction that the vertical component of magnetism exerts on a body is, with small variations, the same as that on any other body. Thus it is that the speed of fall in a vacuum is constant. However, this attraction is not due to mass, it is caused by the magnetism with which the whole body is endowed.
Gravock
gravityblock
Quote from: gravityblock on August 14, 2015, 09:45:47 PM
MarkE must also show proof that gravity is an individualized force and not a combination of phenomena as below.  IMO, the "Travis effect" suggests that the gravitational force is a combination of phenomena instead of an individualized force.
1.) Pressure: As a body on or within the vicinity of the earth cannot be subject to an equal pressure in all directions, the Earth always shielding it from this pressure on one side, the body feels a difference in the forces acting upon it and falls to the surface of the Earth.
A sphere of water in micro-gravity clearly shows the internal pressure within the universe.  Water in micro-gravity, experiences an equal pressure in all directions and forms into a sphere.  The earth, always shielding a body from this internal pressure of the universe on one side, the body feels a difference in the forces acting upon it and falls to the surface of the Earth.
Gravock
gravityblock
Bill,
The variances in the gravitational pull around the earth is much greater than originally thought.  Thus, these variances can't be attributed to mass.
Gravock
gravityblock
The mass density of a material varies with temperature and pressure.  Increasing the pressure on an object decreases the volume of the object and thus increases its density. Increasing the temperature of a substance (with a few exceptions) decreases its density by increasing its volume.
Micro-gravity Combustion (video).  Once again, it forms into a spherical diffusion.
Gravock
